Author Topic: Replacement motor for LT40  (Read 445 times)
Offline randy r
« on: April 26, 2021, 07:54:51 AM »
Replacement motor for up/down motor on LT 40. Where can I find a replacement motor besides WM?  Surely thereís a cheaper price somewhere.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Replacement motor for LT40
« Reply #1 on: April 26, 2021, 08:14:30 AM »
I am of no help with aftermarket because I bought mine from Wood-Mizer.  I have never found their parts prices to be above aftermarket and theirs are always an exact fit.
Offline John S
« Reply #2 on: April 26, 2021, 08:27:42 AM »
I second what MM says,  Why take a chance when WM has what you need?
2018 LT40HDG38 Wide
Offline Southside
    • White Oak Meadows
« Reply #3 on: April 26, 2021, 09:09:01 AM »
I bought some NAPA belts for ONE of my mills one time - KNEW I was saving some $$, being smarter than the man and all.
Yea - did that ONE time.
White Oak Meadows
Offline sawguy21
« Reply #4 on: April 26, 2021, 11:44:50 AM »
Buy once cry once. I don't buy aftermarket unless the OEM is priced way out of line or is too hard to source. Worked as a mechanic, learned that lesson early.
Offline pineywoods
« Reply #5 on: April 26, 2021, 12:04:05 PM »
Why do you need a replacement? those motors do break, but it's usually just brushes. Easy repair. The only other failure I have seen is the permanent field magnets come lose from the case. JB weld them back in place. If you aren't comfortable doing a repair, take the broken motor to your local starter/generator shop. Very seldom can you beat wood mizers prices on comparable items. AND they are always there when you need them.
Offline Mountain_d
« Reply #6 on: April 26, 2021, 12:17:13 PM »
I replaced this same motor last year. Magnet let go on one side. I thought of trying to repair it but went ahead a got a new one from WM. I thought the price was reasonable and here in 2 days. I may repair the old one for a spare. How do you hold the magnet in place as the JB weld sets?  I tried and noticed a very strong force from the other magnet trying to get it into position.
Mountain
1978 TJ 230E 3.9L Cummins 4B, Husky 372XP, Husky 61, Husky 266XP, JRed 625, Husky 265RX clearing saw,  Woodmizer LT40HD 1995, Kubota 4950DT (53hp 4WD), Wallenstein V90 Skidding Winch, John Deere 610 backhoe, 1995 Volvo White GMC WCA42T SA Dump Truck, 2004 Ford F-250SD 4WD, , Central Boiler OW
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #7 on: April 26, 2021, 03:12:48 PM »
I would agree about not trying to find an electric updown motor elsewhere for a WM sawmill.  There's a lot of detail in getting the exact motor rated the same with the same mounts etc, unless you can compare yours side by side with a replacement you will probably end up regretting that path.
Whereas if WM sends you a motor for your mill and it doesnt fit, or work right, they'll make good on it with no extra out of pocket cost to you.
Put your energy into something else that pays off.
Offline curved-wood
« Reply #8 on: April 26, 2021, 04:29:16 PM »
I go in the same way as MagicMan. I think most of the original parts directly  from Woodmizer is not over price. Beside I just dont have time to fit the ''almost'' equal stuff...it's time to saw...the market is hot  :)
Offline slider
  • sawyer,trucker,tree service
« Reply #9 on: April 26, 2021, 04:58:04 PM »
I cant agree more with what has been posted. wm is close on the price on most replacement parts . I am as frugal as you but i have learned over the years .
al glenn
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #10 on: April 26, 2021, 05:53:46 PM »
Mountain
Above all else, whatever you do, DON'T get one or both of the magnets turned around!   ;)
~Chuck~
Retired USAF 1989, Retired School Bus Driver 2012, now semi-retired Mobile Sawyer, 2018 Silverado 4X4
1995 Wood-Mizer LT40HDG25 Kohler - Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Online LeeB
« Reply #11 on: April 26, 2021, 07:03:07 PM »
Are you sure the motor is toast? Check the terminal posts are not loose. Be sure not to let the posts turn when you tighten the jam nut.
Offline slider
« Reply #12 on: April 26, 2021, 07:32:47 PM »
you are so right i have done this several times
al glenn
Motor mount bushing replacement on Wood-Mizer LT40
Started by Bibbyman on Sawmills and Milling
Last post June 07, 2021, 11:06:43 AM
by jimrr
Motor Replacement
Started by jdtuttle on Sawmills and Milling
Last post September 28, 2009, 01:45:11 PM
by jdtuttle
replacement of the motor
Started by harmonbee123 on Sawmills and Milling
Last post October 23, 2015, 01:24:10 PM
by Magicman
H bridge replacement on a lt40
Started by richard lane on Sawmills and Milling
Last post September 12, 2019, 08:46:38 PM
by derhntr
