Author Topic: 2x6x10 treated cheaper then 2x6x10 non-treated  (Read 479 times)
Offline Sedgehammer
  • Old enough to know better, but ya only live once!
« on: May 09, 2021, 10:25:49 AM »
Offline Southside
    • White Oak Meadows
Re: 2x6x10 treated cheaper then 2x6x10 non-treated
« Reply #1 on: May 09, 2021, 11:01:17 AM »
My guess is supply.  Plenty of treated available?
Offline jopoff1981
« Reply #2 on: May 09, 2021, 11:06:57 AM »
If Iím not mistaken the treated is made of yellow pine and is cut in the US and the untreated is fir and comes mostly from Canada and because of Covid itís backed up. Thatís my guess
Offline Sedgehammer
« Reply #3 on: May 09, 2021, 11:33:58 AM »
It's about $6 cheaper here. I suspect people will start using it for studs with that price difference.
Offline Sedgehammer
« Reply #4 on: May 09, 2021, 11:36:12 AM »
It is plentiful in the western states also, but mostly in blue states. I suspect same applies
Online thecfarm
« Reply #5 on: May 10, 2021, 06:28:02 AM »
I myself would not want it for studs in a house. Maybe wrong, but I would not want to breath in all the chemicals in the PT.
But in a out building I would use it.   ;)
Offline firefighter ontheside
  • I like trees.
« Reply #6 on: May 10, 2021, 08:22:49 AM »
I had to go buy some treated 2x4 for the boat trailer at the firehouse and expected to be blown away by the prices for treated, but I wasn't.  Of course they were more than normal, but not what I expected.  I thought they would be much more than regular.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
Kawasaki Mule 4010
Offline Sedgehammer
« Reply #7 on: May 10, 2021, 08:34:27 AM »
Not only that, but one wood need stainless steel fasteners. I can see sheetrock falling off after a few years for those that use it, not knowing it.
Offline Cedarman
    • Cedarusa
« Reply #8 on: May 11, 2021, 07:38:45 AM »
High price of treated makes the phone ring for ERC.
Offline 21incher
« Reply #9 on: May 11, 2021, 06:27:36 PM »
Went  to Home depot and picked  up some  2 x 6 x8 pressure treated.  The non treated 2 x 6 x 8s were over a dollar more. The treated ones were  about 40 pounds each so it has nothing  to do with  shipping  weights  ;D. The non treated were the nicest lumber I have ever seen at HD. Perfectly dry, straight,  flat, and very few small knots.
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a logrite cant hook.
smiley
CCA treated timber
Started by EC on Forestry and Logging
Last post January 19, 2002, 02:31:49 PM
by Don P
Treated ends vs 104
Started by westyswoods on Ask The Forester
Last post February 11, 2012, 10:45:46 PM
by Ron Scott
Pressure treated?
Started by DixieReb31 on Sawmills and Milling
Last post January 06, 2021, 11:47:02 PM
by snobdds
treated lumber
Started by xlogger on General Board
Last post October 15, 2013, 01:03:46 PM
by giant splinter
