Author Topic: Blade guide roller question  (Read 969 times)
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
Re: Blade guide roller question
« Reply #20 on: May 24, 2021, 10:33:33 PM »
It went from "bad" to "worse" over a few hours.
I was trying to limp it along to finish a job.
I was concerned about it catching on fire....
Long story short, if your guide isn't spinning properly, take the time to properly troubleshoot it.
lots of dull bands and chains
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #21 on: May 25, 2021, 07:10:59 AM »
I use Dawn dish soap in my lube tank, might be I should add more!
~Chuck~
Retired USAF 1989, Retired School Bus Driver 2012, now semi-retired Mobile Sawyer, 2018 Silverado 4X4
1995 Wood-Mizer LT40HDG25 Kohler - Cooks Cat Claw Sharpener and single-tooth setter, 4-foot Logrite cant hook.
Offline MobileSawMilSlo
  • New owner just learning and working
    • Mobilna zaga - Slovenia
« Reply #22 on: May 25, 2021, 11:24:00 AM »
Hi
I have the same problem which appears and then disappears. Of course, rollers are set to push the blade down etc.
Maybe it is just my thinking but this happens when too much liquid detergent is mixed with water.
Or too much water is going on the blade and then "aquaplaning" happens.
Woodmizer LT20 mobile and TTP-600 Premium Plus
DAJK - all sawing equipment in one place
Offline Chuck White
« Reply #23 on: May 25, 2021, 09:20:45 PM »
I agree, it could be just like a car hydroplaning across a water puddle on the highway!
As I noted earlier at slow speed, the roller would turn, but at full speed it wouldn't!
~Chuck~
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #24 on: May 26, 2021, 08:18:47 PM »
Lynn, am I correct in thinking the the nut that I loosened is supposed to be tight (real tight) against the inner race on the bearings.
Yes, that nut is holding the inner race secure and it should be tight.  Your description indicates that you have a seized bearing and when you loosen the nut the inner race in turning on the shaft which is not good.  LINK
You have been sawing much too long to suddenly start having lube isues.
Offline Chuck White
« Reply #25 on: May 27, 2021, 07:12:58 AM »
Me too, Lynn!
But I've never sawn Red Pine with this much dead stuff between the bark and the wood!
Going to saw today, start out with no lube and see what happens!
Thanks again to all that provided input!
~Chuck~
Offline Chuck White
« Reply #26 on: May 27, 2021, 05:44:57 PM »
Well, we finished that sawjob today!
No lube, took a little bit of time 1/4 log, then the rollers worked fine.
Really had me pulling my hair out, and wanting to make all kinds of adjustments, but didn't!
Note to all:  If you know your mill is all aligned (by the book) and you start having issues, don't start making adjustments!
As I found out other things can affect the cut and performance, it could be a dull blade, feed speed, or as in my case it just seemed to be the lube mixed with the bug & rot dirt between the bark and the wood!
Thanks again for inputs!
~Chuck~
LT40 Blade guide roller question
Started by CalebL on Sawmills and Milling
Last post February 18, 2012, 11:37:10 AM
by eastberkshirecustoms
my acme band saw blade (captive needle bearing )roller blade guide
Started by buildthisfixthat on Sawmills and Milling
Last post January 16, 2012, 09:34:15 AM
by 5quarter
roller blade guide adjustment
Started by postville on Sawmills and Milling
Last post June 04, 2011, 07:47:54 PM
by tyb525
WM blade guide roller upgrade...
Started by ElectricAl on Sawmills and Milling
Last post September 06, 2002, 06:26:04 AM
by Bibbyman
