Author Topic: Cant reading; 101  (Read 2082 times)
Offline Tony
Cant reading; 101
« on: May 11, 2007, 09:13:00 PM »
      Well I've got another dumb one ::) ::) ??? ???
   I bought a highly recommended log end sealer to seal some red oak logs. I sealed them per instructions. The problem is I can't see the drying checks in the end, there's not one because the sealer is doing its job very well. I've been able in the past to read the checks and turn the log to put the crack\split in one board instead of all of them. I've milled about 400 bdft and probably 300 of it has split. It doesn't seem to matter how I turn the cant. I'm losing some good boards, 12 and 13 inchers and I haven't gotten to the biguns yet. The logs are straight and the bark is not spiraled.
    Do I look at each face and what do I look for ??? ??? ???  Any and all advice will be appreciated ;D
                                                  Tony   8)
TK1600, John Deere 4600 W\frontendloader, Woodmaster718 planer\moulder, Stihl MS461 Stihl 036 & 021 & Echo CS-370
"You cannot invade the mainland United States.  There would be a rifle behind each blade of grass."  Adm. Isoroku Yamamotto ( Japanese
Offline Bibbyman
  • Pro-Sawyer Mary and Bibbyman
    • Warden Sawmill
Re: Cant reading; 101
« Reply #1 on: May 11, 2007, 10:00:10 PM »
I'd take a chain saw and freshen off the ends about 1/2", saw the lumber and stick it and then re-paint the ends of the boards and maybe up an inch or so up the sides.
Sawing since '94
« Reply #2 on: May 11, 2007, 11:49:31 PM »
One thing you can do is take a crayon or log crayon and mark the heart check before you seal the log.  a purple mark layed on top of the check should be visible through the end sealer.
I've marked logs like that when the heart check is small.  It helps to speed things up when they hit the mill.  You can mark a bunch in just a minute or two.
You might be able to scratch enough end seal off of the logs you have not with a little spade, at leasst enough to see the check.
Offline solidwoods
  • Best way to make the most money with a portable mill is to cut the least lumber you can.
« Reply #3 on: May 13, 2007, 07:31:11 AM »
Your orienting the log faces based on end checks?
I guess your talking about a perfect 4 face log.
Logs are oriented to cut based on the defects in the log, not end checks.
jim
Ret. US Army
Kasco II B Band mill
Woodworking since 83
We ship from our showroom.
N. Central TN.
« Reply #4 on: May 13, 2007, 09:52:27 AM »
You have to start somewhere.  I've always used sweep and heartcheck as my first judging points.
Offline FiremanEd
« Reply #5 on: May 20, 2007, 11:10:13 PM »
jim
I agree with Solidwoods. I make my opening cut on the best looking face of the log. The exceptions being severe sweep or a major split.
Full time Firefighter / Paramedic
WoodMizer LT300 as secondary, full time job.
AccuTrac Electric Edger
Offline WDH
  • Forester
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #6 on: May 20, 2007, 11:22:48 PM »
Interesting.  I make my opening cut on the worst face of the log with the best face down on the bed.  That way, when I turn the log 180 to the best face, I am cutting parallel to the bark on the best grade.  Oh well, probably the wrong way to do it........ ::).
Woodmizer LT40HDD35, John Deere 2155, Kubota M5-111, Nyle L53 Dehumidification Kiln, and a passion for all things with leafs, twigs, and bark.  hamsleyhardwood.com
Offline Norm
« Reply #7 on: May 21, 2007, 07:30:33 AM »
I usually make my opening cut on the worst face. My reasoning is that it's most times got bumps or knots or other defects that won't lay well on the mill. I'll slab it heavy so it sits on the mill better and makes the other opening cuts a little more accurate.
I was reading...
Started by Magicman on Sawmills and Milling
Last post July 05, 2018, 09:41:53 PM
by DWyatt
For further reading..
Started by Chuckk45 on Drying and Processing
Last post November 25, 2018, 03:25:51 PM
by Chuckk45
Suggested Reading
Started by WH_Conley on Timber Framing/Log construction
Last post March 23, 2012, 07:43:48 PM
by dukndog
Worth reading...
Started by VA-Sawyer on Drying and Processing
Last post January 27, 2004, 12:29:15 PM
by UNCLEBUCK
