Author Topic: In need of an inserted tooth blade  (Read 1546 times)
Offline ahiggins1
« on: December 05, 2009, 10:46:41 PM »
Anybody know where I could buy a 40 to 48 inch inserted tooth blade?  It is for a belsaw, so I could use a 1 3/8  center hole or bigger and I can use a shim.
Thanks,
Andy
Offline bandmiller2
Re: In need of an inserted tooth blade
« Reply #1 on: December 07, 2009, 08:15:35 AM »
Two things to try Andy,first contact a hammersmith, local best ,they usally have tradeins.Second if their are any local circular commercial mills they update and usally save the old saws for emergency, our economy now is an emergency.Just for ckuckles you could try an add in the local paper there are many leaning agenst the walls in garages no use but too good to junk. Frank C.
Offline sjh
« Reply #2 on: December 08, 2009, 12:16:06 AM »
PM sent.
Offline Carpenter
    • Niobrara Timber and Woodworks
« Reply #3 on: December 15, 2009, 11:55:21 PM »
If you haven't found one yet there are a few for sale on the sawmill exchange.
Offline ahiggins1
« Reply #4 on: December 19, 2009, 01:13:26 AM »
Thanks Carpenter,
I believe I have one tracked down now.
Inserted tooth blade
Started by SCSawyer on Wanted
Last post August 01, 2007, 09:32:38 PM
by woody1
moved
MOVED: In need of an inserted tooth blade
Started by Jeff on Sawmills and Milling
Last post December 05, 2009, 11:16:13 PM
by Jeff
Inserted Tooth Source
Started by Charles135 on Sawmills and Milling
Last post October 24, 2012, 11:14:05 AM
by Jeff
inserted tooth saws
Started by crosscut on Sawmills and Milling
Last post July 12, 2005, 12:59:14 PM
by D._Frederick
