Author Topic: Edger 802  (Read 2051 times)
Offline J_T
  • Some of anything beats all of nothing Even in Dukedom Tn
Edger 802
« on: November 13, 2003, 07:07:45 PM »
Got me a Bellsaw 802 edger today .Never used but been sitting outside sixteen years :( Looked at it when it was first put thare but he would not part with it . Today he gave it to me  ;D But I need parts like the feed rollrrs are rusted away some . Had sealed barrings and we got every thing turning .Any one  know where to find parts ?? Thanks
Jim Holloway
Offline edsaws
  • When in doubt drink stout!
Re: Edger 802
« Reply #1 on: November 13, 2003, 08:08:25 PM »
you might want to ask someone at this link its the belsaw message board they may be able to help http://belsaw.com/wwwboard/wwwboard.html
Offline J_T
Re: Edger 802
« Reply #2 on: November 13, 2003, 08:39:24 PM »
Thanks Edsaws I also need to find hoe many RPM this thing needs to turn.
Jim Holloway
Offline D._Frederick
Re: Edger 802
« Reply #3 on: November 14, 2003, 04:51:38 PM »
J.T.,
I don't know the size of your saw blades, but you should have a rim speed of about 6000 ft / min.. With a 14 inch blade, the rpm would be a little over 1600. If it is an insert toothed blade and is rusty and pitted, you should have a saw shop check it out, (it may start to fly apart if run too fast.)
Offline J_T
Re: Edger 802
« Reply #4 on: November 14, 2003, 06:35:23 PM »
Thanks D Blades are insert bits. They were protected due to the cover. I thought it would be about 3400 RPM .Buddy called Timberking today they got parts for it still.
Jim Holloway
Offline UNCLEBUCK
  • Life out on the prairie !
Re: Edger 802
« Reply #5 on: November 15, 2003, 06:20:52 PM »
Hello J_T , I dont know much about edgers except that I have a old belsaw edger and it has insert teeth and a v-4 wisconsin motor which is twice the size motor that was on it before I bought it in rough condition , it has the feed rollers geared so if I edge at idle speed or turn the throttle up it seems to make no differance so I guess I cant screw up , depends on how fast I want to get done , never have edged over half throttle and it edges through like a 2x very easy at any throttle setting , same for 4x but that gets heavy for one man to lift , I suppose I should stick my handheld tachometer to it and should have a r.p.m. to edge with instead of just how fast I feel like getting done but like I say its geared so I dont think it matters anyway. good luck with your edger and hope to see a picture, I have a picture and a post if you wish to see
Offline UNCLEBUCK
Re: Edger 802
« Reply #6 on: November 15, 2003, 06:30:55 PM »
oh I took off the little angle iron fence on the exit side because it was pinching the blades a bit and now it cuts real well , I hope you get your parts and show us a picture when youre ready , I looked at that belsaw site and saved it to my favorites in case I need parts someday, good luck now !
Offline J_T
Re: Edger 802
« Reply #7 on: November 15, 2003, 09:48:04 PM »
Thanks Unclebuck niceset up . I got a large one cylender wesconson . Good to not get in a big hurry I try not to any more. Gave my digital camary away but will come up with something soon .
Jim Holloway
Offline UNCLEBUCK
Re: Edger 802
« Reply #8 on: November 16, 2003, 09:50:38 AM »
J_T , thats what was on this edger , a one cylinder wisconsin but it had no electric start , kind of a flywheel to hand crank, I will post a pic later tonight of it , maybe its the same motor . The man I bought the edger from edged 2x white oak all the time with that motor , I think there is a rpm speed stamped on the pulley, I go look ! :P
W M Edger
Started by goose63 on Sawmills and Milling
Last post July 07, 2017, 06:24:51 PM
by Darrel
Old Edger
Started by bryantb2 on Sawmills and Milling
Last post March 17, 2019, 09:04:30 PM
by Southside
smiley
MY NEW EDGER!
Started by Stump Jumper on Sawmills and Milling
Last post June 14, 2004, 06:55:40 PM
by Neil_B
Edger
Started by Bruno of NH on Sawmills and Milling
Last post December 27, 2019, 06:25:12 PM
by Southside
