Author Topic: Edger  (Read 1344 times)
Offline ahlkey
Edger
« on: December 17, 2011, 08:32:12 AM »
I am finding that cutting all the fitches using my Tablesaw or WoodMaster rip saw blades while ok may not be the best option?  I air dry everything first, then move them to the dry kiln and after they are dry mill them to dimensional sizes.    I also do a far amount of 8/4 which makes it even more difficult using the Woodmaster rip blades as they cannot handle 2 inch stock.   I try to do most of the edging on the sawmill of course but with a lot of fitches of different sizes I am thinking it would be economical to buy an edger that I could use right off the sawmill.  Locally, I have seen a used Norwood Edger in good condition for under $3500 so I am wondering if those of you that use an Edger find t worth the investment?  Likewise, any advice on manufacturers?.  I do want to buy used if at all possible?
Online customsawyer
    • The Custom Sawyer
Re: Edger
« Reply #1 on: December 17, 2011, 11:15:59 AM »
I love my edgers, and wouldn't want to cut with out one. That being said if I go out to do a portable job that is only a few thousand bf I leave the edger at the house as the amount of extra work involved to take it for smaller jobs is not worth it. A good edger will increase your production but to get the extra production requires extra help.
Two LT70s, Nyle L200 kiln, 4 head planer, 30" double surface planer, Lucus dedicated slaber, Slabmizer, and enough rolling stock and chainsaws to keep it all running.
www.thecustomsawyer.com
Offline zopi
Re: Edger
« Reply #2 on: December 17, 2011, 01:54:36 PM »
I am sure they are worth it for stationary jobs...for mobile jobs the single blade jobby would be cool...goes in the pickup...
I sure lust after one...I hate edging on the mill...it had to be a nice board I am edging for, or that sucker is liable to be firewood...
Got Wood?
LT-15G GO chassis added.
WM sharpener and setter
And lots of junk.
Offline sdunston
  • New York (the great tax state)
Re: Edger
« Reply #3 on: December 17, 2011, 02:25:34 PM »
I have had a WM EG50 for 6 months now and I think it fits my needs fine. It is light enough to put into a pickup and cuts 2'' thick stuff very well...
Thanks Sam
WM LT28, American fordge 18x8 planer,Orange and white chainsaws, NH TC33, IHT6 dozer, IH-H tractor and alot of other stuff that keeps me agravated trying to keep running
Offline ahlkey
Re: Edger
« Reply #4 on: December 18, 2011, 07:09:31 AM »
Wha did the EG50 run you new?   Have you tried using it to cut dried stock?  I have a lot of air dried lumber and if it worked it might be a good option to do before puttting it in the dry kiln.  It would seem it might be harder on the unit give the MC would be closer to 20%.
Offline sdunston
Re: Edger
« Reply #5 on: December 18, 2011, 12:33:25 PM »
Ahlkey I think the unit was around 3000.00, I have run some 5qtr red oak that was 14% and it did not bog down at all. I think WM has a video of one in use
Edger
Started by Rick-Wi on Sawmills and Milling
Last post May 12, 2002, 07:38:44 AM
by ElectricAl
New edger
Started by Plowboy on Sawmills and Milling
Last post February 17, 2006, 08:13:43 PM
by Tim L
edger
Started by jdw on Norwood Sawmills USA Inc.
Last post February 04, 2016, 12:28:24 AM
by jdw
W M Edger
Started by goose63 on Sawmills and Milling
Last post July 07, 2017, 06:24:51 PM
by Darrel
