Effects on blade if milling pressure treated wood
Started by godzilla, April 08, 2012, 11:36:19 PM
godzilla
Hey guys,
The search function has failed me so I will gove this route a go. Long story short, I have a real old house, has sill beams instead of sill plates. To top it off there true 8x8 and one of them, the *almost worst possible spot one is bad. I understand I will need to put Pressure treated back under there to compliy with code so heres the problem. All the stuff I can find is the skinny (non dimensional) stuff and I will have to box something up to fit. I found 8x8 that if I can have 3/4" slabbed off 2 sides I can use the 2x stuff and get my true 8" back under there while retaining a beam. Will milling PT harm a blade? Will a bandmiller run away if I ask them?
"Smell of sawdust stirs my blood"
rmack
you might want to think about wearing a respirator while you are cutting it.
the foundation for a successful life is being able to recognize what to least expect the most... (anonymous)
Welder Bob
2012 LT40HDSD35 Yanmar Diesel Triple
1972 Patrick AR-5
Massey Ferguson GC2410TLB Diesel Triple
Belsaw Boat Anchor
The PT timber wont have any effect on the blade / mill. The thing that puts most people off is the treatment chemicals in the sawdust.
As a one off job to trim up a beam they might be happy to overlook this, put on a dust mask, and saw it for you, especially if it was one of the more modern and less toxic treatments.
Other option, get a species of wood that's naturally rot resistant?  Some sort of cedar, cypress or douglas fir would probably last as long as treated pine anyway. (longer than you or me would need to worry about anyway).
Get local sawyer to cut you some true 2x8s out of something naturally durable, bolt those together and rebuild.
DouginUtah
I believe redwood would meet code, and be a much simpler process.
-Doug
When you hang around with good people, good things happen. -Darrell Waltrip
There is no need to say 'unleaded regular gas'. It's all unleaded. Just say 'regular gas'. It's not the 70s anymore. (At least that's what my wife tells me.)
Maybe just purchase the 2x treated material and rip it to size (table saw or hand power saw) before laying it up into the 8x8 final size.
Wear a mask when sawing and you should be good to go.
Quote from: godzilla on April 08, 2012, 11:36:19 PM
Hey guys,  Will milling PT harm a blade? Will a bandmiller run away if I ask them?
No, and I do not know, but I would not.
redbeard
Personal protection and housekeeping clean up are your main concerns blade life is not noticble, most of the treated beams n posts in my area are white fir and hemlock. I have milled several pkgs. for contrators that needed sill plates with a champhor or angle.
Whidbey Woodworks and Custom Milling  2019 Cooks AC 3662T High production band mill and a Hud-son 60 Diesel wide cut bandmill  JD 2240 50hp Tractor with 145 loader IR 1044 all terrain fork lift  Cooks sharp
MHineman
  If I were doing it for my building and a building inspector was not going to be looking it over, I'd use White Oak, Black Locust, Cedar, or other naturally rot and insect resistant wood.  Otherwise you'd probably need that grading stamp to get the inspector to accept it.
  So, use all the PPE (especially a respirator) and start sawing.  The respirator is actually a good idea with rot resistant wood too, but I have to admit that I usually don't use one, but I do try to have a good breeze at my back.
1999 WM LT40, 40 hp 4WD tractor, homemade forks, grapple, Walenstein FX90 skidding winch, Stihl 460 039 saws,  homebuilt kiln, ......
