Author Topic: Inserted Tooth Source  (Read 1148 times)
Offline Charles135
  • Still Wet Behind the Ears!
« on: October 23, 2012, 02:29:27 PM »
I tried to search the forum, but had no luck.  Does anyone know of a good place to get parts for an inserted tooth head saw?  I have acquired a second blade and it is in need of bits and shanks.  I think it has in it now size "B"
Charlie
Charlie
Foley Belsaw M-14, JD MT, Massey Harris 44, F-30 Farmall, A JD, 3203 JD, 5300 JD, JD 4039 Power Unit
Serving the Thin Blue Line Since 1998
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
    • Behind the  Forestry Forum YouTube channel
Re: Inserted Tooth Source
« Reply #1 on: October 23, 2012, 02:31:37 PM »
Forum sponsor to the left, Menominee saw.  Give them a call and tell them the forestry forum sent you. :)
Offline Charles135
« Reply #2 on: October 23, 2012, 07:42:16 PM »
Thanks!
Charlie
Offline reride82
« Reply #3 on: October 23, 2012, 08:03:09 PM »
I second what Jeff says. I ordered a box anout a month ago and am very pleased with them. Go chrome if you can  ;)
'Do it once, do it right'
'First we shape our buildings, then our buildings shape us'
Living life on the Continental Divide in Montana
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
« Reply #4 on: October 23, 2012, 08:05:57 PM »
I can't agree with chromes. Especially if you hand file.
Offline Charles135
« Reply #5 on: October 23, 2012, 08:17:08 PM »
I was going to ask about the hardened ones.  I use a Andrus Hand sharpener.  I imagine it will take much longer to sharpen the chrome ones.
Jeff, would it make any difference in your opinion of the Chrome one if I were to purchase the Diamond Wheel they recommend for the carbide teath?
Charlie
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
« Reply #6 on: October 23, 2012, 08:23:47 PM »
Honestly, l have always preferred standard bits due to the ease of bit maintenance. The hardened bits stay sharper longer in clean wood, but the same things that screw up a standard bit will screw up a chrome or destroy a carbide.
Offline Charles135
« Reply #7 on: October 23, 2012, 08:32:00 PM »
Thanks Jeff that make good sense to me!
Charlie
Offline Ron Wenrich
« Reply #8 on: October 23, 2012, 08:41:59 PM »
You can hand file chrome bits after you knock off the chrome face.  The Andrus won't do it.  You would need some sort of grinder.  After that, you could use the Andrus.  Chrome will cause the file to wear out quicker.
Offline Charles135
« Reply #9 on: October 23, 2012, 08:45:32 PM »
Ron,
this maybe a dumb question; but, if i knock the chrome face off does that not defeat the purpose of the hardened surface?
Charlie
Offline Ron Wenrich
« Reply #10 on: October 24, 2012, 07:11:01 AM »
Your tooth does its cutting by the edges, not the face.  Although there isn't any chrome on the face, you still have chrome on the edge of the teeth.  If you're used to swaging your teeth, you won't be able to do that with chrome.
I went back to all steel teeth for awhile, but the quality of the steel has slipped quite a bit in the past few years, and I couldn't maintain the edge.  It was cost effective for me to go back to the chrome.  The extra cost was made up with a little less downtime in sharpening.
Offline Charles135
« Reply #11 on: October 24, 2012, 10:35:29 AM »
That too makes since.  Thanks Ron!
Charlie
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
« Reply #12 on: October 24, 2012, 11:14:05 AM »
I quit sawing in late 2005, and was starting to notice the decline in quality of the bits a couple years before that. I'm sure I probably griped about it here somewhere. :D
They have a bunch of knowledgeable people at Menominee. Don't be afraid to ask advice from them on your given situation.
In need of an inserted tooth blade
Started by ahiggins1 on Wanted
Last post December 19, 2009, 01:13:26 AM
by ahiggins1
Inserted tooth Removal
Started by Charles135 on Sawmills and Milling
Last post October 30, 2012, 05:10:21 PM
by Jeff
Inserted tooth blade
Started by SCSawyer on Wanted
Last post August 01, 2007, 09:32:38 PM
by woody1
inserted tooth saws
Started by crosscut on Sawmills and Milling
Last post July 12, 2005, 12:59:14 PM
by D._Frederick
