Laptop dying?
Started by Magicman, August 10, 2010, 05:12:27 PM
Maybe this is good news to some, but my laptop appears to be dying.  At times, it just goes to a white screen.  All that I can do is turn it off, then back on, and let it reboot.  Firefox will resume back to the point where I was.  Nothing is lost.
My question, is there a way to save all of my "Desktop" and "Bookmarks" to a CD or flash?  That way, if/when this thing doesn't come back up, I can at least install all of that on to a new one.
ronwood
in Firefox select Bookmarks option at top of page. Then selected organize bookmarks  and then import/backup and finally export to html.
LT40HG25 Woodmizer Sawmill
LX885 New Holland Skidsteer
 :) :)  One small step for man.  Thanks.
ronwood
pineywoods
Magic, it may be just the display. The cable to the display gets bent every time you open or close the lid. Sooner or later the cable breaks. on the back side there will probably be a jack for an external monitor. Plug a regular desktop type monitor in there and it should display whatever is supposed to be on the laptop screen. I've extended the life of several laptops by doing this. One customer even bought himself a nice big flatscreen monitor. If you can use a big ole crt type monitor, come visit, I'll give you one or two or three. I collect them from the dumpsters...
Thanks, Ron.  That was simple enough.  Since I had the stack of CD's out, I went ahead and backed up those neglected pix files also.  It takes a while, but not nearly the heartburn that will be involved when this old gal croaks.
Piney, I'll keep that display tip in mind, but if this display dies, I'll replace the laptop.
