Author Topic: Any Worm Grunters on Here?  (Read 800 times)
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« on: April 26, 2015, 09:42:01 PM »
Good video.
Offline fishpharmer
Re: Any Worm Grunters on Here?
« Reply #1 on: April 26, 2015, 11:06:43 PM »
That's unique for sure.  David, you gonna try worm Gruntin?
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #2 on: April 27, 2015, 07:45:02 AM »
Company that I started work with owned 1,000,000 acres in the Perry, FL area.  We sold permits to the worm grunters to grunt worms on Company land.
Offline Jeff
  • Fearless Leader
  • Oh la di oh la da
    • Behind the  Forestry Forum YouTube channel
« Reply #3 on: April 27, 2015, 08:09:47 AM »
Saw that done the first time on dirty jobs.
Offline fishpharmer
« Reply #4 on: April 27, 2015, 08:17:24 AM »
Mike Rowe is almost as humorous as Poston.  ;D.    Makes me wonder if  worm gruntin will work in other parts of the country.
Offline doctorb
  • Unofficial Team Physician
« Reply #5 on: April 27, 2015, 08:39:47 AM »
We used to mix a little powdered mustard with a glass of water and put it down a worm hole in the lawn at night.  Night crawlers would pop right up.
Online WV Sawmiller
    • Green's Sawmill Services
« Reply #6 on: April 27, 2015, 10:02:00 AM »
I grew up in Escambia Florida  north of where this took place but I did go fishing for a week with a pseudo grandfather there when I was  teenager. Plus we used to visit my grandfather in Dixie County Fla and fish the Suwanee River south of there. We bought earthworms that came from this area (Blountstown). I knew they had worm grunting contests there very year. Nearby is the own of Two Egg and their annual festivities include a Possum beauty contest.
The soil where I grew up was too sandy and not real conducive to earthworms. We had wigglers and red worms. My wife grew up in North Ala and they would sometimes vibrate them up. She called them Fiddle worms and the technique fiddling. They'd sometimes saw off a small tree about 2' above ground level then use the handsaw to vibrate or fiddle them up. I've heard of folks taking the chain off a chainsaw sticking it in the ground and revving it up to vibrate them out.
Where I live now we have plenty of night crawlers. They also grow to 10"-12" long and as big around as a pencil. Last summer I became expert in catching them. For best results you need fresh mowed short grass. They will be in bare areas but are really spooky there. After a soaking rain on dark nights is best. A dim headlight works better than a bright one and some folks use a red lens which I will try this year. You walk slowly watching the outer edge of your light beam. Look for movement, shine then shape. Movement is usually the first telltale. When you find him he will be partly out with his tail in a hole into which he will quickly slurp back into if alarmed. Often it is hard to tell which end is the head and if you grab for the wrong end he will likely escape. What I found works best is to pin the worm with one finger then determine which is the head end and grab the worm from the other side of your pinning finger as close o the tail end as possible. Don't try to pull him out too hard as he will break. Just hold pressure till he releases. Friends of mine say they give slack then pull. Evidently the worm thinks he is free and will release his tail hold. I find the steady pressure technique works better for me. I've heard of pouring dishwater on the ground drives them to the surface but I can't swear to it.
I'm sure other places have some bigger worms but really big ones here occasionally loosen boulders on the hillsides and start landslides and when caught have been known to dislocate someone's shoulder so be careful.
Worm or bug
Started by goose63 on Sawmills and Milling
Last post September 07, 2017, 11:13:56 PM
by Stuart Caruk
Worm Drive Saw Oil?
Started by kantuckid on Timber Framing/Log construction
Last post August 28, 2022, 03:20:10 AM
by SwampDonkey
Rotten worm
Started by Den Socling on General Board
Last post January 17, 2012, 05:31:07 PM
by Den Socling
Spruce Bud Worm
Started by jerry sundberg on Forest Education
Last post October 15, 2019, 06:10:27 AM
by jerry sundberg
