Useful sawmill mods
mesquite buckeye
I'm guessing the small bolt broke off inside the handle.
Mine just used to vibrate out. now they are properly rusted and stay put. ;D
69bronco
Good looking bead there 4x!
Peter Drouin
Mine kept falling off until I lost the thing. So I grab an allen wrench, Fix now. :D :D :D :D
4x4American
I had to weld it because the blade bit off the head of the bolt.  It's right in the line of fire.  The other one taint far from being bit off.  Look at the dowel that plugs into the top hole for the cover, that things been gnawed on a time or two I'd say...
Boy, back in my day..
 :o  In two years??   ???
Peter Drouin
He's hard on things MM. :D :D
 :o  I am wondering how many thrown/broken blades it took to caused that many tooth marks.   ???
Peter Drouin
Quote from: Magicman on June 01, 2016, 08:49:26 PM
4 :D
4x4American
 :D :D :D
MM don't ever sell your mill!
4x4American
I wanna see what the inside of Jake's covers look like on his Hazelhurst 70...they are prolly a lot lighter than they were new
Mine is 18 years old.  You don't wanna see the claw marks on it.   :o
Czech_Made
Nothing wrong with blue flame fix  ;D
Quote from: 4x4American on May 31, 2016, 10:06:16 PM
The drivers side cover busted off the handle and the dust shield collector unit mabobber..I welded the chute thingy, nothing special, but I wasn't sure if the handles were weldable with my wire feeder and solid wire and argon/c02...so I tried it, and it worked...really noting special but I figured that if someone had same problem it might be good to know u can weld it.
reswire
Hey Bibby,
Do you know of a way to increase the lift head motor on a LT 40 HD?  I love my mill, but the head life is painfully slow sometimes, and I'd like to make it faster without buying the super!!   ;D ;D  Is it simply a matter of changing a motor, or is it more to it than that?   Any ideas?
Norwood LM 30, JD 5205, some Stihl saws, 15 goats, 10 chickens, 1 Chessie and a 2 Weiner dogs...
grouch
Quote from: Ga Mtn Man on September 12, 2014, 08:59:44 PM
This thread has gotten so huge it needs an INDEX!
Here 'tis. Rough and in chronological order as they appeared in the thread. Not sorted by type of mod or whether brand-specific or generic. Just chrono index. Dunno if Bibbyman can edit the first post to include this (or even if he'd want to), but here 'tis anyway.
Needs work, but I need a break.
reverse bolts on Wood-Mizer cover plate
two sacrificial boards for sawing shorts
12V fuel pump for priming diesel engine
hydrostatic carriage drive and chain hoist for log turning
R.V. level on mill
platform for WM walkers
carriage return switch
changing Wood-Mizer from mobile to stationary
2nd battery, oil pressure, tach, micro switches on clutch handle for lube and engine, marker lights, spot lights
lights to tires, head, posts
spring to LubeMizer tube
hydraulic solenoid valve indicator light
glass sediment bowl
garden hose to cover leg hazards
hydraulic hose to protect loader ram fittings from breakage
sleeve to hang fenders, wrenches, ammo box
block of oak to replace bearing
movable scale becomes special scale
file for blade
Moon hubcap as skid
buddy bearings and spare tire
scale and log lights
light for night sawing
brush for bark fuzz, rounded power strip, fenders filled for billboards
manual to power back supports
guard as belt cleaner
forward battery box, keyed switch, oil pressure, tach, 3 inch backstops
stainless steel bolts with Nylock nuts
double head chain, lights, line levels, jack
water tube relocate, deflector protector
sawdust drag with overhead return, table spacing
throttle activated windshield washer blade sprayer
other manual back support converted to powered
lever mod, switch for 2nd loader arms, no tongue
chain turner idler
solid square for chain turner rollers
dragback deck extension
tape measure magnet
board guide
replace blade tensioning lever with nut
loader mod for short logs
wrench hanger
hook and bar for earmuffs and gloves
DC fan for sawdust
DC fan for sawdust
closet basket
umbrella
handle bars and throttle
traction for step
sawdust chute cover plate
ramps and extensions for offloading timbers
handle for shifting side stops
sawdust exhaust chute
fork to clean sawdust chute blade stoppers
chain substitute for dragback cable
dragback motor prop
castors for outriggers
bicycle tach on idle wheel
gearmotor for head height
toe boards via ratchet binders
load lock as log dog
gearmotor replaces winch for head height
blade guide motor rubber knuckle saver
convex mirror
balanced guide crank, ice tea bottle hand grip, oil filler sleeve, battery outlet/plug, cutout in mainsaw guard
air quick connect
oil fill extension, dust chute
contact strip bypass with welding leads cable
DC to AC hydraulic pump
manual log turner handle
roller toeboard
accuset buttons for gloves
squaring arms
6 gpm AC hydraulic pump
log dogs
battery box
battery box
battery box
rail guard and battery box dust sucker
scale and magnets
splatter shield
hydraulic tank heater
log stop scales
LED tail lights
roller chain board guide
tubing light protector
mechanical remote controls
gear oil drain plug
dragback arm pivot joint pin
water drum, hose, tap, pump, switch
tape measures and magnets for scales
umbrella on accuset
LubeMizer retrofit
water tank with air hose quick coupling
offbearer table with roller
roller chain board guide details
sawdust chute clean-out fork
water lube to drive side, 2nd valve on lube tube
home made autoclutch for LT40
custom tool boxes
custom aluminum fuel tank
dishwashing detergent jugs for lube
ratchet strap for head during travel
washer with hairpin clip for head during travel
remove hydraulic decal plate
tripod and electric winch for log turning
battery hold-down, battery isolator
heavy sawhorses for mobile dead deck
battery terminal short prevention
bucket for sawdust discharge
forkliftable toolshed
blade cover and log dog mods for Oscar
hydraulic cover traction mod
dragback removed for larger cant
7 ft bed extension for LT15
hour meter, exhaust re-route, cold air intake restrictor, choke cable removed
truck mudflap sawdust deflector, Norwood
duck tape Honda fan intake
trailer jacks
blocks for stabilizers
wedges for stabilizers
Log Arch Mill Deck, Mark I.
12VDC gearmotor speed control
trailer axle front
rubber bumper protectors
boat winch to worm gear winch
nuts as loading arm teeth
cam cleat and rope control for dragback arm
calculator and cyclocomputer
umbrella mount using nut rivets to seat
Ambidexter Thermostropter
removable log stop extensions
sawdust discharge chute
hinged unloading ramps (for timber), bed extension with removable bunks
broken blade for log clamp teeth
blade storage
half-pipe sawdust collection trough
12VDC winch log turner
saw lube solenoid switched by engine rpm
lube tubing extension and re-route
lube tube extension and re-route
dragback guide fingers
hydraulic toeboard reposition
plastic drum blade storage
Magic Can
cut-down garbage can with expanding foam, blade storage
clamp fangs
clamp fangs
seat umbrella
LT15 clamp mod
Norwood log loader extension plus winch
belt cleaner tool
stainless steel lube tube with bushing
hydraulic control center mods, 3/8 drive socket tensioner, deflector board
see-through debarker flap
lube mixer side shield relocate
marker lights as hydraulic solenoid trouble lights
board return arm lower lip added - Wood-Mizer
modified plastic jug guard mod for LubeMizer upper jet
board return (dragback) arm lower lip added - TK 2000
LT15 clamp bolts as pins
dust chute scoop welding and cover warpage
modified (angled) board return arm lower lip
clamp fangs, traction nuts, nut locks, umbrella holder
end of mill backstop
log shifter for loader
clanger
gun bluing rails
removable bed rail risers with cant stops, electric winch turner / loader, extra battery
bondo spreader as blade cleaner
Norwood sawdust chute deflector from tire
external battery and 5.5HP engine with 105A alternator
NO-OX-ID "A-special" for electrical connections
BX backstop mod
ball valve and needle valve for lube control
carriage activated lube valve
valve and tee for "breeding the system" and washing hands
request for explanation of "breeding the system"
suggestion for "INDEX"
fine adjust outrigger from jacks
fine adjust outrigger from jacks - step by step
permanent band shield keeper bolts
clamp lock bar mod
lube tube reroute
forstner bit for clamp teeth
water tank
lock for compressed outrigger pin spring
smaller alternator pulley
replace drive-in grease fittings with threaded
steel dragback roller table
dragback fingers and holder, dragback deck
TK hinge in dragback
mill as edger with vises
upside down broom on offloader
3rd toeboard
voltmeter
exhaust extension
HF log dog shortening
allthread plus coupling nut log dog, acme thread log height adjusters
HF track extension
welded dust shield handle
OneWithWood
Nice work, Grouch.  Appreciate it  8)
One With Wood
Savannahdan
Grouch:  Thank you for the index. I've spent almost an hour looking at some of the modifications.
Husqvarna 3120XP, Makita DCS7901 Chainsaw, 30" & 56" Granberg Chain Saw Mill, Logosol M8 Farmers Mill
pineywoods
Quote from: reswire on June 02, 2016, 08:47:58 AM
Hey Bibby,
There's more to it...The bigger motors need more electrons ie bigger alternator, then the drum switch contacts aren't husky enough. Search for "faster up for older woodmizers"  I didn't post it in the sawmill mods thread. There's an update which I haven't posted yet, but will do so asap..
mesquite buckeye
Quote from: Savannahdan on June 02, 2016, 10:39:28 AM
;D ;D
stihltoomany
This thread needs to be a book on sawmilling. Thanks for the index. I never have managed to read this entire thread. This will really help.
Way too many saws, mostly STIHL
Bobcat S650, Bobcat 331 excavator Bobcat A770
and other dirt toys
Looking for hyd bandsaw mill, Timberking used maybe? NOT anymore!
WoodMizer LT40 super
Ga Mtn Man
Hey Bibby,
I share your opinion on the speed of the head.  When I first got my mill the slow speed drove me nuts compared to that of my previous mill, which was hydraulically driven.  As an experiment, I changed the lift motor pulley on my LT40HD Standard to the same size pulley as is used on the Super mills.  I reckoned that there must be some excess lifting capacity since the mill can be ordered with much heavier engine options than my mill has(G29).  The motor had no problem lifting the head and, as expected, was about 50% faster but... the SimpleSet was no longer accurate at that speed, as much as a ΒΌ" off.  After playing around with all of the hidden settings on the SS without any success,  I spoke with Rick at WM and was told that it can't be made to work without a firmware change, which is not available.  Changed the pulley back and just got used to the slower speed. :-\
Bandmill Bandit
Hey Bibby,
I have tried a few thing but ultimately have not found any thing that really makes a lot of difference short of changing out the lift motor to the same one that is on the super with the wood mizer upgrade for that purpose.
It is the ONLY upgrade I have NOT done on mine to date and probably wont be doing. All the other upgrades combined made a very significant production improvements and in running the mill since all the upgrades I find the head lift speed is not as much of a noticeable issue any more.
There is a spring assist mod somewhere in the usfull mods but I found it made the head a bit to "lite in the cut" as you approached the lower cuts in the log.
I some times wish i had done the super lift motor upgrade BUT only because I could have added the full set works II instead of just the simple set.
With I all said and done i am very happy with my mill and head lift speed is a very minimal productivity factor if at all as my mill is now operates. The hydraulics, feed motor and simple set, board return with the out feed table and laser site, in that order will give you the most productivity increase you can get.
With all that done the lift motor becomes a matter of milling experience to get the head where you need it BEFORE you are ready for the next cut.
Chuck White
Quote from: Bandmill Bandit on June 02, 2016, 03:57:04 PM
Hey Bibby,
There is a spring assist mod somewhere in the useful mods but I found it made the head a bit to "lite in the cut" as you approached the lower cuts in the log.
It's called the Piney Wood's lift assist.
I found that this system helped increase the speed a lot, but a year later I upgraded the motor and the gear box.
The lift assist is cheap and easy to do.
Ga Mtn Man
I have tried a few thing but ultimately have not found any thing that really makes a lot of difference...
It seems like you didn't read my post.   :-\
You absolutely can increase the speed (by about 50%) just by changing the pulley but, the SimpleSet won't work correctly.
Quote from: 4x4American on June 01, 2016, 10:02:11 PMMM don't ever sell your mill!
OK, you pictured yours so I'll let you off of the hook and post up mine.
There are plenty of claw marks, but none are freshly done......yet.   ;D
Self modified sawdust chute.  Kinda like the monkey said when he got his tail caught...it won't be long now.   :-\
It's only 17" long now.  A broken blade tore a hole through it which was constantly catching sawdust, especially ERC, so I whacked it off.
