Head Raising Mechanisms - descriptions
Started by slowzuki, September 30, 2004, 07:03:44 PM
slowzuki
Trying to finish off the mill and the garage door spring 'taint gonna cut it to lift the electric motor!  I've got some ideas to work with I'm gonna list, lets hear yours!
-power (acme) screws
pros-
simple to motorize, balance and install, self locking
cons-
time to order, cost
-hydraulic cylinder (turner mill style)
pros-
simple to power, powerful, accurate/infinite positioning, self locking
cons-
would add 3 ft to height of my mill, cost
-cable winder gearing added the garage door spring
pros-
garage door stuft is there already, easier to motorize
cons-
Worried about torque on set screws on garage door cable drums, non-self locking
-Chain walker like WM
pros-
Proven design, easy to motorize, self locking
Cons-
Cost, parts aren't available in town
-Chainfall hung over top, pull chain run through exhaust tubing and rewelded so it is in better location.
Pros-
have chainfall, self locking
Cons -
difficult to power and route pull chain, balancing
I'm leaning powerscrew but could be swaying.  Comments? Additions? Anything? ;D
slowzuki
Well, some math here, 200+80+40+80  about 400 lbs give or take I'm guessing?
QuoteWhat's the weight of the saw head?
Can ya do some kind of counter balance along with the overhead door spring? How about two springs, one for each side of the head.
I think someone on the forum is useing a 12 volt winch for up and down. Just get power in/power out.
Let me look at my mill.
slowzuki
Well, the overhead door spring is sort of a counter balance.  It is taking about 125 lbs load right now.  I can't fit another due to space.  I can get a heavier spring to take 225 lbs or so of load but still not enough and I have no locking.
I have a 12 volt winch but the mill is 220V so no dice.  I could run a worm gear cable winch to provide some pull and self locking like the little wood buddy does.
Ken
QuoteCan ya do some kind of counter balance along with the overhead door spring? How about two springs, one for each side of the head.
Wudman
Slowzuki,
I'm using Acme threaded rod (1" x 5 threads per inch).  I built a four post head and have a rod on either side connected by chain and sprocket.  I welded a 3/4 inch bolt to the top of one rod and use a Milwaukee reversible drill to raise and lower over large distances.  I attached an old steering wheel to the other side for fine adjustments by hand.  The system works very well for me. I'm using a 5 HP electric motor so I'm a little lighter than your setup, but the Acme rod should handle anything you throw at it.
I am gathering parts to add some hydraulics to the mill, and when I do I'll probably use a hydraulic motor to turn the Acme rod.  By the way, I haven't had any problems with sawdust messing up the system.
Wudman
Charlie Daniels
I was kinda thinking an actual weight and cable run through several pulleys. "Could" make it small, but still might be in the way. ::)
Heck, that overhead door spring isn't taking much, is it? :-/
slowzuki
I've run out of room to add more pulleys unfortunately and the spring drums are about out of room to store wire...  Actual garage doors use 2 springs and they only weigh 200 lbs or so.
Ken
QuoteI was kinda thinking an actual weight and cable run through several pulleys. "Could" make it small, but still might be in the way. ::)
slowzuki
Wudman, what do you use for thrust bearings at the bottom or top?  And what do you use for engaging the head to the screw? Just a nut or more to it?
Thanks!
Ken
QuoteSlowzuki,
Wudman
Wudman
Ken,
I used flange bearings at the top of the rods, so the head is basically hanging from those bearings.  At the bottom, I just welded an acme nut to the head.  It's a simple system and very solid.
Wudman
Charlie Daniels
slowzuki
ex-racer
Regarding the cost of Acme powerscrews and the followers (nuts) for them, I got some from old hospital beds.
The ones I got were 1 inch diameter, and moved exactly 1/4 inch per turn, which was perfect for a manual (crank handle) operation.
Flange bearing pic below.
Ed
redpowerd
im a little confused on your design from these posts, but it sounds a bit like the Kasco design. mine uses threaded rod attached to the carrage, with a threaded sprocket (one on each corner)linked with a chain to a reversable dc motor.  the rod is attached to the carrage with
a pin, so fine tuning the rig to the carrage is as easy as removing the pin and twisting the rod up or down. im sure larry_copas wouldnt mind snapping some photos for ya, he may allready have some!
NO FARMERS -- NO FOOD
northern adirondak yankee farmer
slowzuki
Ok, thats what I pictured for a flange bearing, I've got them on my garage door spring setup.  Wouldn't have guessed it could take that much thrust load.  Do you use a split collar to keep it from pulling out?
So where does one find old hospital beds eh ???
QuoteRegarding the cost of Acme powerscrews and the followers (nuts) for them, I got some from old hospital beds.
Bruce_A
Trailer tongue jacks might be an option.  Replace handles with sprockets and chaindrive.
Wudman
Bearing thrust loads was/is something that I was/am a bit concerned with.  I'm not sure what they can stand, but I'm not turning them at any speed so bearing failure shouldn't be any problem.  With that said, I made sure nothing could fall if a bearing failed catastrophically.  The flange bearings are sitting on top of their supports, with a hole drilled through the support being just a tad larger than the 1" rod.  I tack welded the bearing stop collar to the Acme rod, because I knew I was loading the whole deal with some thrust forces that It wasn't really designed to take.  Even if I have a catastrophic bearing failure, the stop collars would prevent anything from falling.
Wudman
Charlie Daniels
redpowerd
wudman, your lifting mech isnt attached to the rig but to the carrage?
the kasco uses stationary rods, i take it yours move. lemme look see if i have some of larrys pics.
Wudman
Red,
That would be correct.  My Acme rod turns.  At the top they are suspended in the flange bearings.  At the bottom, an Acme nut is welded to the saw carriage and the rods thread through them.  Turn the rods and the head will travel up or down.  Right now I am using a Milwaukee variable speed drill to power up or down.  It works pretty good for me.  When I make it to a more permanent location, I'll probably put a hydraulic motor on it.
Wudman
Charlie Daniels
GF
I used acme rods on mine the head itself along with the 30HP 4 cyclinder weights about 1500lbs.  I dont think I would weld the nuts, I would build a "u" shape bracket to go around the nuts that keep it from spinning and then bolt that to the frame.  Should the nut ever need to be replaced just unbolt the u bracket and unthread the nut.  This also will allow you to fine tune each side or corner individually by loosening the u bracket and turning the nut to the next flat area.  Thats how the one is I built.  I use a hydraulic motor to power mine up and down.
GF
Also if you run the threaded rod throguh any type square tubing make sure to make the hole oversize or put a bushing through the tube, otherwise your acme threaded rod could catch the edge and strip a thread, i used high tensile strength steel rods on mine they are 1" X 6' and cost around $48 each.
D._Frederick
Slow-,
I would not rely on a set screw to provide the holding power to transmit the torgue required to raise or lower your saw head. At the minimum, you should drill a seat in the shaft for the head of the set-screw to fit in, the problem with this is that the set screw will work loose. If you have a milling machine, you could cut key-ways. On my mill, the sprockets were pinned to the shaft with roll-pins, never had a problem.
Bruce_A
Has anybody thought of using cab jack hydraulics like they use on semi trucks?  Jack it up and release to lower.
slowzuki
Re the set screws, no I don't like em.  I think the garage door spring is getting replaced by acme rods.
Cab jack? Tell me more!  :P Is it a multistage telescoping cylinder?
Ken
Gilman
Ken,
Since you have AC available, why not look into just duplicating the WM version?  Reducers are relatively cheap, same for the motors.  The best part is that method is already proven.
http://www.surpluscenter.com/sort.asp?numrec=20&lastrec=60&sort=1&keyword=PGRC&catname=powerTrans&UID=2004100122413279
If you need some help figuring out how to size your reducer, let me know and we'll work it out.  Else iff please keep us informed on what you decide to go with.
WM LT70, WM 40 Super, WM  '89 40HD
Cat throwing champion 1996, 1997, 1999. (retired)
Bruce_A
Just a small diameter hydraulic cylinder used as a jack to push a cab forward and up.  Similar to a two piece hydraulic jack with the pump being seperate from the jack. About 18 to 20 inches of throw.
