Other topics for members => General Woodworking => Topic started by: xlogger on September 04, 2016, 07:46:03 AM
I'm not much of a woodworker but was thinking about building a router sled. I'm cutting more live edge slabs and some mostly maples are cupping, they are getting over looked when people are looking. Because most do not have a way of flattening them. My planer is only 20" and most are over 20.
Anyone got a Woodhaven planning sled? I looked at them online and they look good to me.
I try not to get into the woodworking part of the sales but I'm getting several slabs that are stacking up.
I bought all the rollers and stuff ready to build one for my mill.
I got this coming.
(https://forestryforum.com/gallery/albums/userpics/39553/Bowl_Router_Bit_sct_888.jpg?easyrotate_cache=1473495125)
I bought the Woodhaven but never used it, not because it's not a quality system, but because I wanted something that would work on a larger scale. It's still on a shelf in the shop. I built this instead:
https://forestryforum.com/board/index.php/topic,80966.msg1232193.html#msg1232193
Lots of options to build sleds using wood rails. Here's another one I studied.
https://www.youtube.com/watch?v=qtkBZHLJyD0
ESFted, I missed your router sled thread the first time. Cool build. 8)
Quote from: xlogger on September 04, 2016, 07:46:03 AM
I ran into that problem also. I met a guy that runs a large cnc router full time. He flattens large slabs for woodworkers and gave me some of his business cards to pass out when I saw a slab for a customer. Besides flattening the slab he can also joint the edge and cut slots for counter top connector bolts typically used for mitered corners. Those bolts really simplify glue-ups when working with live edges. You might check to see if anybody is doing the same in your area.
I bought a huge router bit at woodcraft and still have the actual sled on the to-do list. Start posting some in progress pics and that should kick me into gear to create mine. I have two walnut pieces I left open after a fresh cut and they started to warp a little, need to get those bottoms flat again.
What is your budget for the project I am trying to keep it below $50
