Husqvarna 61 Model / Serial What year were these made?
Started by MN Cutter, October 21, 2012, 08:28:40 PM
MN Cutter
Hello All
I searched for a thread to give me my answers but was unable to find it.
I am working on 2  Husqvarna 61's that I have ordered parts for from my "local" 90 miles away Husqy dealer and I have received incorrect parts and was hoping someone can tell me the age of these saws so I can look up the correct parts myself and hopefully get the correct items so I can finish these up.
1st one   Tag # 061148   Recoil cover has 61 on it, has white cover with Rancher sticker
2nd one  Tag # 5231758 Recoil cover has 61 on it, black / gray cover
Thanks in advance.   Matt
Stihl  390,260, 026, 261
Husky 51 & 61
Gehl 5635 Skidsteer
J.D. 620 Gator
04 Ford F350 with Boss V plow
Homemade 30 ton splitter ;)
Just want to warn you on the serial number. I have an old echo trimmer,maybe 20-25 years old,needed a fuel filter for it. I called them,with the model # they needed the serial # too. Got it for them,could not find it. Only 20 minutes away,so I said I'm on my way,with trimmer. They never did find the number. The numbers they had was not even close to mine. But put an after market filter and I was all set. I kinda did want to know how old the trimmer was. I brought it new.
lumberjack48
I owned 4 or 5 of these in the late 70's early 80's, i really didn't care for-em. It was underpowered for felling and bucking up. If your not in a hurry to get something done, it well make a good saw. The 162 was a go getter, i owned a few of-em, nice felling an limbing saw, fast little saw. The bad thing with the 162, i couldn't keep a muffler on it, ruined a few heads trying to get studs out. Then i went to a 266, now this is the saw you want, power, very responsive, just a perfect all around saw. The carb on the 266 was very weather sensitive, i carried a screwdriver so i could adjust it if the weather changed a little to keep it running to my specs.
Heres some specs on the 61
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/0c94bcf3d89fd46a88256b520016407f?OpenDocument
