Coiling blades
Started by Jerry, November 11, 2009, 05:08:55 PM
John Bartley
I no longer coil my blades. I set them inside each other until I get ten of them in a stack, then I put them into a wood case. It takes less room and is much easier to deal with.
cheers
John
Kioti DK35HSE w/loader & forks
Champion 25hp band mill, 20' bed
Stihl MS361
Stihl 026
Flatheadyoungin
but when you are a chicken........ :D
yeah, i have quite perfected the technique of grimacing, holding my face sideways, leaning back, being ready to run, and throwing the blade at the same time........quite effective....
even though i've only done one sawmill band the rest have been small bandsaw blades :-\ ;D
If the customer is there, I tell them to watch closely because I coil the first one and they must do the rest......then watch their eyes pop out.... :o   :D
backwoods sawyer
Throw and run is what you do with a grenade. Doing the same with a saw can be just as dangerous when it jumps back at you. Slow and steady with care and they will unfold with out all the excitement of an alligator chase. Not to mention that you will be able to saw wood with out leaving marks from the bent teeth.
Tom that was a good set of photos showing the complete process.
As for gloves if I have them on then I keep them on, if I do not, then I do not go looking for a pair to put on. The saw is not moving in your hand.
If you are having trouble getting the saw to brake over, hold the saw like Tom is in #5 and push it against the corner of a log being carful not to hook a tooth and take a slow step forward and the saw will brake over.
Backwoods Custom Milling Inc.
pineywoods
I still throw and duck.. Ever notice that a thrown blade will uncoil with the teeth down in the dirt at least 90 % of the time?? why ? I coil the bands off my woodmizer without a problem., but I do use welders gloves. Neighbor brings over some blades off a norwood. They are short and I never have gotten the hang of coiling them.
Dodgy Loner
I use the foot-on-the-band method to coil my blades. I tried the method Tom demonstrates and was never able to get the band to fold over. I don't use gloves and it hasn't been a problem. I don't like gloves and never use them, but my dad won't even take a blade off the wheels without gloves on. I also toss the band to uncoil, but we have a lush lawn of bermuda grass that makes it less worrisome as far a damaging the teeth. I think a more controlled method would be nice, but frankly it scares me worse than just tossing them on the grass.
Dan_Shade
like bandmiller said, get a long lawnmower belt.  the process is the same to fold it up, and a lot less catastrophic if you make a mistake!
lots of dull bands and chains
rickywashere
moonhill
Not only did he have gloves but glasses too :o
Tim
This is a test, please stand by...
rickywashere
Quote from: moonhill on November 15, 2009, 07:00:59 AM
Tim
thats the only thing i would change if it was me i dont like gloves around any kind of blade to many loose things to get caught .. i guess that comes from my use of a old hand crib block mill ///
Hale87
I just did the bounce and twist thing yesterday for the first time.
Man was that easy.
Thanks for the tip.......
2002 LT40HD sawmill, WM single blade edger, 23hp Kubota tractor, 2011 Kawasaki Mule, 2002 Honda Foreman, 1983 Case 480D backhoe
jwoods
Coiling and uncoiling blades isn't too bad IMO.
My last order of re-sharps from Cooks were flat-packed, 14 blades in a kidney-bean shape (one inside the other) held together with a "C" shaped piece of flat-bent metal.  I was positive my wife would have to take me to the ER whilst trying to get them all separated.
Joe
Quote from: Hale87 on November 16, 2009, 09:07:56 AM
Man was that easy.
NOW you can impress your customers.....  :D
backwoods sawyer
Quote from: jwoods on November 17, 2009, 08:15:52 AM
Joe
You are not alone. The first few that you take out of the bundle tend to not do what you want them to. :o It seems that you need three or four hands to ease them out. whiteflag_smiley.  I will go find a pair of gloves when unboxing a new set of saws.
If you throw the un-opened band on the sawdust pile to unfold, the sawdust keeps the teeth out of the dirt  :).
Chuck White
Once you have mastered coiling and uncoiling bands, try inverting the band without the band touching the floor/ground!
Like most things, it's easy once you know how!
moonhill
Whoa, someone surrendering and putting gloves on :o  while dealing with bands!
Tim
OK, I'll admit that I am a whimp.  Gloves, back support belt, welder's apron, steel toed boots, hat, safety glasses, dust mask & ear plugs when I'm sawing.  I keep the gloves on when coiling a band..... :D
Dan_Shade
I like the ear muffs
Life is peaceful with earmuffs!
Quote from: Chuck White on November 17, 2009, 06:39:31 PM
...try inverting the band without the band touching the floor/ground!
The easy part is doing it and not knowing how it happened.  :D
Papa1stuff
When you have your own sharpener and setter you get to invert each and every band ,after 20 or 30 you get to do it pretty well ;D
1987 PB Grader with forks added to bucket
2--2008 455 Rancher Husky
WM CBN Sharpener & Setter
You're right Papa1.  I have turned a lot of them, but, I'll have to admit, I use my foot and both hands.  :D
Papa1stuff
I do it by putting the blade under a board  teeth down ,lift up and twist in or out with both hands and it inverts very easy!
I guess I could use a board, but I step in the center-bottom and hold it at about 9 and 1.  Then I roll it.   It goes pretty easy that way too.
moonhill
When inverting the band for sharpening start with the teeth facing toward you so after the result the teeth are facing away from you, it is the last snap that "gets ya".   Yes a board or scrap of something to start from.   Don't forget to turn the band back after sharpening, they don't cut well backwards.  I had a old time sawyer watching me once when that happened.  I wondered if he had ever installed his big circular saw with the teeth going the wrong way?
It is not uncommon for me to find a cracked band while inverting them, they sound and feel different.
Tim
