Tree diameter vs bar size
Started by SasquatchMan, January 02, 2004, 04:51:58 PM
SasquatchMan
What's the biggest tree a guy can fell with 16" bar?  I understand that you can cut a big open face notch, bore from that side, then cut the rest of the felling cuts from the backside of the tree.  But what is the practical limit for this technique?  What is the impractical (theoretic) limit?
Senior Member?  That's funny.
Kevin
It would depend what you are cutting on a regular basis to make it practical.
I can cut just about everything with an 18"bar and still have plenty of power .
That's for felling,limbing and bucking.
Most of the stuff I cut is 20" or smaller.
If I stumble into a 20"+, I can get by with what I have.
If I was blocking firewood in large wood I might opt for a longer bar and a bigger saw.
SasquatchMan
Question is, how big COULD you possibly do with an 18" bar?  What's the limit to the size of tree you can fell with even the fanciest of footwork?
Kevin
You can get about a 36" back cut with an 18" bar but it ain't practical.
You can center punch the hinge from the face and get even bigger wood but it still ain't practical.
Corley5
I cut a 42" on the stump willow in Dad's backyard last year with the 395 and 20" bar.  No big deal but if I had to cut stuff that big on a regular basis I would surely have a longer bar in stock.
I'd say the theoretical maximum dbh you can cut is probably 2 1/2 times your bar length.. maybe 40" with a 16" bar?
It does however take a bit of planning and more skill than I have to do it.  ::)
As the other guys suggest, if you gonna come across many trees that are 2 times your bar length, it's time to get a bigger saw ;)
etat
On big trees we used to cut as much as possible with an 18 inch bar, and finish up with a crosscut.
rebocardo
imo, 24 inches.
I was forced to cut a 36" oak with my 18" Poulan because my Husky decided to quit in the middle of the notch and it was too unsafe to leave the tree alone since my truck was anchoring it.
Being in front of the tree to get the middle of the notch with a small saw is a lot more dangerous than standing to the side of the tree. I hated it.
The thing is you have to be pretty good to get the notch spot on for direction with a saw that is 2x smaller than the tree. I had to recut mine 3 times before I got it correct.
The other thing is the dogs will take off a good 1" from your ability to cut deep, along with having to worry about burying the nose of the saw doing the back cut.
I had thought about cutting it using a different technique, but, this water oak was irregularrly shaped and it would have been difficult to predict how it would react to anything other than an open notch.
The other thing is how the saw is going to do pulling chips that deep inside the stump. If you are cutting something like oak, it really slows the saw down because the chips/curls do not fling out like they do when you are bucking a tree and the chain is dragging on the wood if you are cutting at anything less than a perfect 90 degrees..
L. Wakefield
   I very much like your answer. Part of my perspective is from exreme inexperience and knowing that I want SAFETY, SAFETY, SAFETY. So I want lots of margin on where I can stand and not the need to do precision maneuvers in a potentially dangerous position.  lw
SasquatchMan
My original question is sort of a safety one, in some ways.  I'm not fond of having a 24" bar all the time - risk of accident is just a bit too high... but on the other hand, if a guy has to get super fancy with a 16" to cut bigger stuff, that's not so safe either.  Catch 22
dan-l-b
Hey Sasman,  I think the answer is- two or more saws. Safety says the more power the longer bar, the quicker get away from the big stuff and then safety says switch to the mid size saw for limbing so you don't wear yourself out with that 066 or such.  I am in that quandry myself but on the wrong end.  Have a 039 and 066 and a029.  The 039 is OK for limbing and bucking the limbs into wood ( grampa likes burning them rounds) but it gets heavy.  The 029 is just too small ( grampas saw ;)) so thinking about a lighter (than the 039) husky (they are my favorite saw though you couldn't tell) for the drudery of bucking boocoo tree tops. :) :)
Ed_K
 Safety wise, I like a tree not to move,till I release it from the backcut. To prep this I use 2 saws, a 2171 johnsred and 345 husky. If the bole is 18" or less, Its just the 345 for the whole tree. 36" I notch and bore, (drop)with the 2171, then switch to the 345. Anything bigger I use a 394 husky.
 345 w/ 16" bar
 2171 w/ 20" bar
 394 w/ 24" bar
 I don't like front boring unless its a $ butt log.
 Note: if you get use to limbing with a short bar, dont use use a long bar. I got lazy last week and didn't pick up the 345, and ended up sliceing my chaps, not enough to grab fiber, but enough make me realize I was tired.
Ed K
Frank_Pender
Ed K you hit on the biggest safety issue of all, tired.  I always run 36" bars on my big saws; 2, 044s and 1 066.  For the small stuff around the mill I us an 025 with a 16" bar.  Even for short time usage in limbing I use the 025.  For the big timber, over 16" I will use one of the 44s or the 66 simply for safety in speed of cutting.  If you can't remove the chips fast enough,  I have found you can end with a real safety issue with getting the back cut through to the face or hinge point.
I have fallen 24" Fir with my 025s but, like what was said, there is a safety factor in makeing sure your back cut aligns with your face for directional falling.   But, I have only been doing this for about 45 years, what do I know? :-/
IndyIan
I was just thinking about what everyone has written and I came up with a strange thought.
Assuming you're cutting sound trees, I think the fancy cuts you have to do with a short bar make felling safer.
I like doing the plunge back cuts because it lets me perfect the hinge and then I cut the strap.  I haven't fallen too many trees and I don't like cutting a normal backcut where I'm still finishing the backcut as the tree begins to move.  I'm afraid I'll cut through the hinge or leaving to much.  I think not messing up the hinge doing a conventional back cut takes alot more skill and experience than doing the plunge back cut and cutting the strap when your ready.
Also doing all the fancy cuts lets me enjoy taking down the tree that much longer!   ;D
Over on the arboristsite chainsaw forum a member has been posting videos of his felling and to me it looks like it takes a lot of skill to finish the back cuts well.  He makes it look easy though.
A tip the chainsaw course instructer gave me was to always aim at something when you are felling.  Stick a stick into the ground 30' away and try to put the trunk right on it.  This keeps us recreational cutters sharp(or not so dull :) ) and is good practice for when it matters.
rebocardo
I know a pro would not do this, but, I did it on my last job because the tree was big, irregular, and covered with vines and I did not want to lose my way in the cut.
After removing some vines I spray painted a level circle all the way around the trunk and then sprayed on my notch to make sure my cut was dead on for both sides. It worked.
Frickman
Rebocardo,
I don't want to brag about being a pro, but I have been cutting timber a long time, and I frequently do what you did, except with the saw. On most trees, and all valuable butt logs, I will make wing cuts on the sides of the hinge to stop fiber pull in the outer part of the tree. You make these after cutting out your notch by cutting down at an angle, sometimes making a horizontal cut to make a mini notch, about one inch deep. If you cut this at the same level as the notch it makes a great reference point when you start your back cut. I carry a red lumber crayon in my pocket, and use it sometimes like you did with paint to mark large trees.
An old lumberjack told me once that if a tree took 50, 75, or 100 years growing someplace, the least you can do is take a few extra minutes to cut it down properly instead of butchering it up. Thats why I take as much time as I have to when felling timber to make sure the job is done right.
Kirk_Allen
Frickman:  Your felling process is what I was taught by my father, who has felled trees for over 60 years.
It works great and to date I have dropped a few big ones by Illinois standards.
The largest was an American Elm with a 50" base.  I used my Husky 372XP with a 28" bar.  (upper bar limit for the saw)She dropped right where I wanted.  I like to think that it was because of great felling skills but I know some luck was involved.
I then bucked 8 1/2' sections with the same saw.  Ended up with 8 logs all measuring 8' 6".
rebocardo
Frickman, I agree with the 100 years thing and doing it right. I will have to try that wing thing, I never heard about doing it that way, though it makes sense.
L. Wakefield
   I like those last 2 ideas. I am much better off if I am trying to follow a line cutting than if I am just winging it. Never had paint with me, never thought of scribing it with the saw- but it makes perfect sense.  lw
Swede
My first thinking when i read the question is: How long teeth has a beaver and how big trees can he fell? ;D
I like the Frickman way and have used it. If You apply it proper it´s safe...... even if it´s a kind of beaver way.
Swede.
Had a mobile band sawmill, All hydraulics  for logs 30\"x19´, remote control. (sold it 2009-04-13)
Monkey Blades.Sold them too)
Jonsered 535/15\". Just cut firewood now.
You're back, Swede!  I get to say welcome.  :D
Hope you'll take pictures and show us Smålad, Sweden sometime. :)
Swede
Thank You Tom!
 I´ve a problem to bring You a picture, think I need an URL for it, or?  ???
Why dont You come over to the Kingdom of glass?
If you have the photos, then.....
click on Forum Tools at the top of the page
and then
Uploading Photos.
When you put your pictures on the Forums Gallery they are there for all to see. ;D :)  .....and you can link them into your post too. :)
Are you referring to Sweden as the Kingdom of Glass or do you have a website?
Swede
Thank You for telling me about how to bring a photo. One day..........
Kongdom of glass = this part of Smålad. There is about 15  glassfactorys less than 80 km. from here. One small glassfactory is my neighbor. I worked there till -85, when i started < www.maskinotryckluft.com >. Last summer i found the idea about mobile sawmilling and decied to by one.
You have all kinds of interesting things that you could tell us then.  Pictures of Glass factories would be neat.
I can't interpret your language on the website but it seems to be describing a generator company.  Be sure to put the website address on your profile and, if you get the chance, describe what your company does.  Do you build, assemble or just retail/wholesale? :)
