Anyone know anything about taking off a flywheel on a Stihl saw? It has woodruff key on the crank shaft, shaped like a half moon and flat. It's a FS550 brush saw, but doubt it can be much different procedure.
Flywheel off Stihl FS550 item #1. The two threaded sections to either side of the centre of the flywheel are worn out. Causes a clankity-clank noise when she spins.
(https://forestryforum.com/gallery/albums/userpics/11009/SD_flywheel.jpg)
Woodruff Key item #12 That bearing you see is in behind the crankcase. The threaded end of the crankshaft and the key are outside.
(https://forestryforum.com/gallery/albums/userpics/11009/SD_woodruff_key.jpg)
Now does the woodruff key keep the flywheel from slipping during rotation on the shaft or from pulling off the shaft? or Both? And if it keeps it from pulling off, what do I use for a tool to depress it some way or some how, to get the flywheel off? It can't be that mysterious. There's nothing to the darn thing. I took the brass nut off already. I notice a slot in the flywheel next to the shaft. I have another diagram of a woodruff key on a gear shaft.
Not a crankshaft in this picture. Item N is the woodruff key. Same set up on the end of the saw crankshaft though.
(https://forestryforum.com/gallery/albums/userpics/11009/Woodruff2.jpg)
Any fish? ;D
I have a small puller and use it to put tension on the flywheel. Then I use a small brass hammer to tap on the end of the crankshaft (with the nut installed to protect the threads). The taper of the crank shaft is what keeps the flywheel on the crank, the key is just to keep it from rotating.
I figured after examining it some more I had to use a puller. My puller I borrowed is too beefy. I'll have to maybe get another one with slimmer jaws. My crankshaft has a hole bored for the tip of the puller centre bolt. I am working in a cramped space because there is a crankcase held together by screws in behind the flywheel and in the way for the most part except maybe at a couple points to get a 2 claw puller into. I've got every other screw out including the muffler, fuel tank and the carburetor. :D I've gotta do some cleaning on those anyway. I soaked the rust reaper to the shaft for the night. ;)
Thanks.
on a stihl saw i use a cut down piece of 1/2 in pipe with a nut welded in it . thread the pipe into flywheel and use nut and bolt to remove
I see that can be done on my brush saw to, it's threaded inside the flywheel. I can even pick one up already made.
Thanks for the insight. ;D
Most of the Stihl models except the larger models use a 22 mm by 1.5 thread spacing internal thread on the flywheel .These can be purchased often on E-bay .In my case being a tight wad I make them from a metric hydraulic fitting . I think on that so far I've shipped out about a dozen and a half .
Al, got a part number & brand on the fitting? I started tearing down my 026 for crank seals tonight.
Ed
This has worked for me for the past 15 years, so it should be simple enough for you:
Remove the flywheel nut and spray a bit of WD40 or similar stuff onto the crankshaft/flywheel
Screw the flywheel nut in till its outer surface is level with the crankshaft tip.
Hold the engine by the flywheel.
Tap on the crankshaft tip sharply, once or twice.
That flywheel should come off.
The woodruf key is only for holding the flywheel in the correct position for proper ignition timing,while the nut is tightened down, so that the flywheel can sit tight on the taper of the crankshaft.
Joe
I was given that option to Joe. But didn't like the idea of whacking the crank shaft too well. You can't really hang on the the flywheel too well that way, since the crankcase surrounds it and only comes off when the flywheel is removed. Screws in behind the flywheel. ;)
Al my flywheel is 22 mm as well, end of shaft is 8mm (5/16") diameter.
Got a couple requests in on ebay for shipping cost. By the time I run all over creation to find a hydraulic fitting, I might as well get it off the internet. I learned that a long time ago in this area. No matter what, they won't have what you want. :D
The flywheels I've removed I just put a center punch in the end of the crank, then whack it hard with a heavy hammer. Of course, the saw will shoot across the bench, which it has to to work, don't clamp the saw down!
Quote from: Ed on March 12, 2010, 10:44:15 PM
Ed
It's just a "bango " fitting .They come in different tubing sizes with a 22 mm threaded part on the end ,straight threads not tapered pipe threads . I get mine from discards at work out of the scrap tubs .I imagine though for what they cost you'd be about as well off to buy a puller as to buy the fitting and make your own .
Now I'll tell ya what .I'm going to take a chill pill and give it a shot once again downloading a picture .I have never had any luck so far but if I do I'll post a picture of a homemade puller .Unless some kind viewer of which I've sent them too can help out and load a picture . Too early in the day for chill out medicine,maybe after the sun is over the yard arm . :D
Al, send me the picture and I'll post it for you. 8)
I don't think I have your E-mail B .Let me check .
I thought I sent you a puller .If not I will .
Quote from: SwampDonkey on March 13, 2010, 03:42:44 AM
You dont want to hang on to the flywheel, fine, just hold a big screw driver between the crankcase and the flywheel and apply pressure onto the flywheel as if you are trying to prise it off with the screw driver, then tap the crankshaft .
With the nut flush with the crankshaft, dont worry, you will not damage the crankshaft.
Well, if you still feel you're not upto that, the only other tool that can do the job is the Stihl flywheel puller # 1110 890 4500.
Is this the image Al?
(https://forestryforum.com/gallery/albums/userpics/15459/2396/flywheel_puller.JPG)
This is one of the most common of Stihl pullers since it is used on brushcutters like the FS500, 550 or chainsaws such as the 260 , 360,380 and ... yes the 460.
The outer thread goes onto ther thread on the flywheel hub.
Hold the puller in place with a spanner and screw in the inner bolt. Voila!! The flywheel comes off the shaft.
This puller would be in use with every Stihl servicing dealer.
Joe
Quote from: joe_indi on March 13, 2010, 12:02:23 PM
That's pretty much it Joe .I've made several different ones using various sized bolts depending on the size of the internal openings .Some with 1/2" 20 thread ,m11 -1.5 ,1/2"- 13 TPI .Just depends on what I have around at the time I'm making them .
Rocky should have a pic on here shortly .
AL and Joe, how do ya like my flywheel puller? I had to make it a little different as they didn't have that type fitting with 22 mm x 1.5mm thread. Accept they did have one with the proper thread on one end for the flywheel and then another screwed on (silver) to the back. I drilled a hole a 5/16" hole in the silver fitting, threaded with a 3/8" tap. Ground down a nut a little thinner and tapered a bit, because of space inside the silver fitting. Took 3/8" threaded rod and cut a 3" piece off. Screwed the thin nut onto it so it came up flush to the brass color fitting, turned on the back fitting until it came flush to the nut inside and the whole assembly hit flush onto the end of the crankshaft. Put on a lock water and nut on the outside of the threaded rod until flush to the back of the silver fitting. These are 1" fittings, means it takes 1" wrenches. I have the pulley assembly off the back so I put a ratchet onto the crankshaft nut back there. Turned the home made flywheel puller onto the flywheel threads and pop goes the weasel. ;D
Thanks for the tip Al. Here are some pictures to study. :)
(https://forestryforum.com/gallery/albums/userpics/11009/SD_HM_Gear_Puller-004.jpg)
(https://forestryforum.com/gallery/albums/userpics/11009/SD_HM_Gear_Puller-003.jpg)
(https://forestryforum.com/gallery/albums/userpics/11009/SD_HM_Gear_Puller-002.jpg)
Less than $10 bucks and eBay wants anything from $8.50 to $35 plus shipping. ;)
I tell ya right now that no screw driver and taps would'a took that off, at least not on my flywheel.
Looks like I'm late to the party, but here's Al's picture. :)
(https://forestryforum.com/gallery/albums/userpics/11183/131/case_split_002.jpg)
Thanks for posting that .I might add that the center of the bolt was turned to a point to engage with the centering hole of the crankshaft .Kind of similar to the factory made puller . It was little tough to do on a grade 8 bolt through,hard like a rock .
I'm not one who likes to beat on the end of a crankshaft to get the wheel off .Fact is for every make of chainsaw or engine I have and need to pull the flywheel I fabricate something that will work .Whatever ,however anyone else does with their own saws is none of my business and I'll leave it at that .
After thought .There is a puller that I thnk was designed for Mopeds that is reversable .It has a M22 on one side and M26 on the other .M 26 is used for larger Stihls but I've never personally had the occasion to need that size as yet .If I can find a fitting some place though I'll make one or have one of my toolmaker buddies turn me one .My lathe will not cut metric threads .
It's a good old Monarch 10" EE ,one of the best but it has a few years on it .Back when noone ever thought that the USA would ever be metric . The change gears for that thing to cut metric would cost a bloody fortune if I could even find them .
Looks like you'd have to buy an English/metric gearbox for that EE Al. Probably only set you back 30 grand. :D
Quote from: Al_Smith on March 13, 2010, 02:39:40 PM
Well Al, some of those flywheels need the tap at the crankshaft for removal.Here is a flywheel removal tool from Stihl which is used for just that on various engines including the 019.
(https://forestryforum.com/gallery/albums/userpics/15459/2396/flywheel_releasing_tool.JPG)
I'm good to go.... 8)
Had to stop a the Deere/Stihl dealer today, nothing there, all Deere ag equipment still uses inch fittings.
Hmmmm, wonder if "Blue" tractors are different, only a mile away.....they had a few metric fittings, including what I needed. 8)
Little time on the lathe, little time with the welder, back to the lathe, drill, tap.....all set. Popped the flywheel off so easy it wasn't funny.
Ed
I got the crankcase split in half today and pulled the bearings and seals off, they're pretty much gone to snot. Ordered some replacements, ain't cheap I'll tell ya that. :D
Thank goodness for Rust Reaper, for pulling all that old metal off. :) 8)
Got the crankcase all back together today. All's left to hook up is the fuel lines and the throttle cable. 8)
The Stihl company is extremely proud of their parts which they try their best to make all OEM .Some seals can be cross referenced at about 1/4 the the cost but most cannot including bearings etc . You just have to bite the bullet because you have very little other options .
The bearings are not an easy thing to get for most of them, as you say. My know it all brother thinks you can just walk into a shop and get them for $8-20 :D Good luck on that one. His mouth sometimes gets ahead of his brains. ;) Even the ones in the angle gear are double sets of ball bearings inside and $60+ each, there are three. I think one is about $100 bucks. :o And that gear housing has to be heated to get them out, which means you burn up the seals of them all, so might as well buy a new angle gear. :D I tried using hydraulics to get the two bearings off the gear to the blade. Nope no way without heat to get them out of the housing. :D
The bearings I got for the crankcase come from Portugal. The seals are two sizes as well.
I've never even seen one of those clearing saws much less worked on one .On the chainsaws though often times the flywheel side bearings and seals are standard metric . It's the clutch side that are the odd balls and are more expensive .
That OEM stuff is just typical German mindset design ,they all do it . Good stuff just costly to repair .
I deal with that type stuff daily on high speed machinery used in the auto industry . It's not all that tough to repair,finding the parts is where the real battle is .
They don't seem to be that bad to work on, just delicate work is all around some things. Anxious to get back finishing up this saw this morning to see how she runs. So I'm off, now that it's daylight. ;D
I bought a puller and my brother said you'll use that once and never need it again. Well, I've used in 4 times already in the first week. Slicker than a side walk dog turd. :)
Quote from: SwampDonkey on March 19, 2010, 03:18:43 AM
The bearings are not an easy thing to get for most of them, as you say. .......
This clearing saw is a fine example of German over engineering.I think it was introduced sometime in the 90s.
The Bearings are similar in size to those on a 046.
The bigger oil seal is the same as the one on the clutch side of a 046, 026 036 ora Stihl blower.
The smaller one is the same as the one on the flywheel side of the 038.
The Portugal bearings are from FAG. Though the NTN ones are also available.
Heating the gear head to remove the bearings are a real messy job because you end up with a couple of ruined components. So I tap out the pinions without heating the body.
Once all the cir-clips are out, just tap the driving end of the gearbox on a wooden block the pinion with the small bearings will come off.
Using a big wrench socket,the thrust washer and the lock nut a rudimentary puller is formed which will pull out the driven pinion
Hydraulics didn't bring her out, so it's not so easy as you think. All it did was start to dent the mouth of the housing on the blade end. :D
Tapping won't loosen that sucker on the drive gear neither, the inside of it came out easy, but the outside ring of the bearing is tight to the housing. And you can't get a grip on the housing because it's all rounded and you just tear at the housing in a vise as it slips like a greased pig.
Quote from: SwampDonkey on March 19, 2010, 05:28:04 PM
Now how pray tell can you gat a greased pig in a vise .That would be a job in itself . :D
Now you know the dilemma. :D :D
Aside from that little tale, I'm now trying to piece that throttle back together with all them springs and switches. Oh, the joys. ;D
This morning I looked over my throttle again and found a spring not seated properly. So I put that into place and closed the two halves back up and adjusted the cable with a screw driver below the palm release lever and she's fixed. Went and cut a few clumps of dogwoods in the back yard and trimmed the apple trees of some lower limbs. Rock-n-Roll. ;D :D
Couple pictures for ya Al. :D
Same saw, but about 4 years ago.
(https://forestryforum.com/gallery/albums/userpics/11009/SD_SpacingSaw.jpg)
(https://forestryforum.com/gallery/albums/userpics/11009/SD_SpacingSaw2.jpg)
Aint she a beaut (brute :D).
If I am not mistaken she has the same cubics as a 029.
And the 550 has been around for quite some years.
We dont see 550s here. Nothing over the 400.
Joe
Quote from: joe_indi on March 21, 2010, 10:03:58 AM
Joe
56.5 cc's 12500 rpm
That's because only professional bush whackers are privileged. ;D :D :D :D :D :D
Well, I'm proud to say that I had no break downs this season on the rebuild. I also added up all my areas for the season and I cut over 40 ha. That's over 100 acres of brush on that one saw this year, thank you mam. Stihl all the way! 8) 8) 8) :)
Thats alot of ground covered with any saw . 8)
Quote from: SwampDonkey on November 21, 2010, 04:17:58 PM
Excellent! I just hope you have a good chiropractor. :D Swingin' my Husky 165r for a few hours does me in....
Ed
Cut another 60 acres on the same saw this year. I was marking areas out for the most part of the season. Had to replace the angle gear though on the front end, and I snapped off a handle bar. Nothing out of the ordinary when your in big softwoods. ::) Surprised that old clutch is still holding up. Same original throttle assembly to, although I have a spare with me. 8)
Are you done with thinning for this year?
Time for a new and interesting project eh? ;D
Yeah, finished up a little bit ago. Going to load up with some new lumber in a week or so for a "mystery" project. ;D 8)
Styhl going strong. ;D
Noticed the last couple days that the low end of the rpm's was sluggish. Suspected something was blocked of course. Filters are new and clean, lines clear, new carb. kit this spring. Finally removed the muffler, it was just about closed off with carbon in the exhaust port. Cleaned it out, works like new. Back in form. 8)
