DIY log dogs, show me yours!
Started by Satamax, August 23, 2015, 05:31:44 PM
Satamax
Hi everybody.
Well, i've done a google image search on the forestry forum, for log dogs/clamps. There's plenty of results. But it's all scatered around. Wouldn't it be nice, for wooden tops like me, to be able to come here, and have a thread with all the options availlable in?
So guys, flash your log dogs. Nope, not talking sausage and bread  ;D
Few big pictures, with a description, about what they're made of, how. And why they are good, superior or bad. Ideas on what you would do different if you had to make some more. Every type is welcome.
Thanks a lot.
Max.
Kbeitz
Well I'm still not happy with mine. It's just to slow. But it works just fine.
I started out with 1-1/2 rack with 1-1/2" round welded on the tale end.
This killed two birds with one stone. The round part is the dog stop that swings up or down to meet the log.
The rack part is adjustable to the size of the log. I tried the cam-lock type and I did not care for that what so ever. so now I'm using thump screw type until I find a better way.
Love machine shop work
and Wood work shop work
And now a saw mill work
Kbeitz
I changed the round pipe to square .
The whole thing would twist sideways with the pipe. The square tubing keeps it from twisting.
york
Albert
Satamax
Thanks a lot guys.
Kbeitz, i like the round part, with the flat which can go up or down.
York, your system is posh!  ;D I realy like the guided ram for the dog itself.
Guys, keep them comming.
Thanks a lot.
Max.
kelLOGg
This idea came from FF member RobNRob2.  I put 4 of them on the mill.
Bob
Satamax
Well Bob, i should admit i can't see much!
hackberry jake
Hydraulic Turner/Clamp. No more bending over.
justallan1
The system I made is mainly set up for small pieces, 11" and longer. I saw more burls than anything else and so have this set to where it doesn't interfere with the factory clamps on my tracks. For small pieces I feel you have way more stability with having the 3 points of contact to you log or burl independent of each other. The way I built the clamp does use less than half the room as the stock clamps. It works great for what I'm doing anyhow. The reason behind 2 spots for the stops to go is for funny shaped pieces so they aren't in the way of the carriage traveling down the tracks.
hackberry jake
That looks like a pretty good set-up for cutting cookies as well.
justallan1
It should cut cookise fine. I get trees that are basically burls from the bottom up and cut the caps off first, so with only the 2 stops and the clamp I can hold a round of wood or burl that nearly max out the mill. The nice thing is that I can clamp a burl at absolutely any direction that I want to get the very best cut without losing a thing.
kelLOGg
Quote from: Satamax on August 24, 2015, 07:55:24 AM
Hope this is better. First one shows clamp biting the top of the cant.
This shows biting the bottom 1/4" of the cant.
Satamax
Thanks a lot guys.
That starts to give me ideas. Keep em comming ;D
Satamax
Hi everybody!
Well, I think I've found a good solution for the serious diy'ers.
Lengthwise hydraulic curb clamps. In Europe we have some simpler ones than the one below. Two square tubes of different sizes, sliding in each other, and an hydraulic ram to actuate the movement.
This, or hydraulic fork holders for telebooms and forklifts.
