stihl 310 vs. husky 460
Started by smith2bj, November 23, 2009, 11:01:18 AM
smith2bj
Which is better between the 2 or are they really about the same?
Cut4fun
I thought WTH 310 v/s 460  :o, then I seen Husky 460 2nd time.  Thats why people need to read a sentence twice before replying.
Go run them them and see whats feels right to you. If you need dealer support for everything, that would be very important too in the decision.
Rocky_J
Just say no to mediocre saws.  :D
cuznguido
Are you implying that the Husky is an inferior saw? ::)
Rocky_J
No, I'm implying that the MS310 and Husky 460 are mediocre saw models. I wouldn't buy either one, although I guess they are better than a lot of the junk sold out there.
And I own 7 Huskys and 5 Stihls.  ;)
ladylake
Pretty much a toss up, the 460 might have slightly more power with the 310 being built slightly better.  Steve
smith2bj
Rocky_J I agrre with you 100% and thats why I have a Jonsered 2171 and a stihl 361.  i am not a fan of the cheaper saws but my father-in-law baught the husky 360 and I was going to sell him a stihl 310.  Looking at them they look like the same saw just different names.  I would have recomendded a 2165 or the 361, but what am I going to do.  I just wanted to know a little more about the saw.
nmurph
there is nothing wrong with a 310. well it is a little heavy and has a clamshell design, but they are as reliable as gravity, parts are readily available and are cheaper than the pro saws. it depends on how much wood you will cutting and what your pocketbook says. i tell you what, you buy one and i will help you with a muffler mod that will put it cutting uncomfortably close to a 361/357 and you will have money left over for pair of chaps, an extra chain, and to take your significant other to dinner. if you are not happy with it, your money is only an ebay sale away.
smith2bj
nmurph
Red 93 L1 #3383
I have a 310 & it's a good saw for the money.
Stihl's: 2-064AV's, 020T, MS 310
'93 Ford F-150 Lightning, '94 F-150 4x4, '92 F-150 4x4 '80 F-150 EFI 7.5L, '04 Expedition (Wife's)
MartyParsons
Brand   Husqvarna   Stihl
Model   460/18     MS310/18
Displacement    60.3   59.0
Power (hp)   3.7   4.0
Weight/ph    12.8   13.0
P/W Ratio   0.29   0.31
Fuel capacity    14.9   18.9    (OZ)
Chain pitch   3/8   3/8 rsc3
ladylake
 I think Stihl has the HP numbers over rated on the 290. 310 and 390 saws, the ones I've run were no where near the power stated when compared to other saws with less HP.   They have the MS290 at 3.8 HP and the MS260 at 3.2 HP yet they cut just about the same.    Steve
John Mc
Quote from: ladylake on November 28, 2009, 05:38:37 AM
I wonder if this is a question of torque vs HP? Perhaps some of the other saws you're comparing have a wider torque band?
John Mc
nmurph
hp figures have been independently confirmed, it's just that they are a bit peaky; power drops significantly above peak hp rpm.
ladylake
Quote from: nmurph on November 28, 2009, 01:06:05 PM
I don't believe Stihls numbers or the independently tested numbers for 1 second, Stihl can fudge the numbers and either buy off the independent  tester or send them a ringer when they run the test.  There is big money to be made from getting the HP numbers higher on a low cost saw.  Most decent 50cc saws with the same or less HP numbers will cut faster than the 56cc MS290 no matter how you run the 290
nmurph
who's numbers do you believe? this could be said of all manufacturers.
John Mc
Peak rated horsepower is not the whole story in how well a saw cuts anyway.
ladylake
Rated numbers mean nothing, if I have a 10.5#  50cc saw that cuts faster than a 13#  55cc saw I'll call the 50cc saw a good saw even if the rated hp is less.     Steve
smith2bj
what is that little tweek that I can so with my 310 to make it run better?
Cut4fun
Quote from: smith2bj on November 30, 2009, 10:39:31 AM
Muffler mod and carb retune in 20 mins and for free done yourself.  I had a MS290 on the bench to test on and gained 23% faster cut times with muffler mod and fine tuning the carb afterwords to new muffler openings.
smith2bj
what do I do to it?  Is there anywhere online that I can go to to see how it is down?
Cut4fun
There is no need to uncrimp or remove cage on this muffler. It is very restrictive with only 2 small slits for opening from the factory.  PM sent.
