Gearmatic 19 disassembly
Started by Jsblair8, April 13, 2025, 10:35:50 AM
Jsblair8
Cleaning the gearmatic 19 winch on my Timberjack 404. I've removed primary brake band and both clutch bands.  I can't get the anchor pin out to remove the secondary brake band.  Its really stuck.  Any suggestions as to how to get the pin out?
Much appreciated.
bushmechanic
That pin should have a threaded hole in the end of it so you can install a slide hammer to it and knock it out. Also you can thread a bolt into it and use a impact gun to start it turning in the bore.
