Homemade sawmill tracking issue
Started by GARose, May 07, 2024, 11:48:31 AM
GARose
I am building a sawmill using pillow block bearings for the band wheels and I notice the bearings move and throw the blade out of alignment or off the wheel.Is there a rule of thumb for aligning the bearings to help stop this? Thanks
fluidpowerpro
Where are the bearings located. Both on one side of the wheel or one each side?
Either way, typically you need a means to adjust blade tracking. This can be done with sort of a "jacking" bolt that pushes on the foot of the bearing. Once it's positioned properly, then the bolts holding the bearing torqued down tight.
Change is hard....
RAYAR
Really need some good pics to see your set-up to better understand what needs to be done.
mobile manual mill (custom build) (mods & additions on-going)
Custom built auto band sharpener (currently under mods)
Husqvarna 50, 61, 254XP (and others)
96 Polaris Sportsman 500
2006 Ranger 4X2 w/cap, manual trans (431,000 Km)
