Bimetal blades
Started by Beavertooth, May 07, 2018, 11:09:07 PM
Beavertooth
For anyone who doesn't know if you buy 1 1/2" bimetal blades from wood Mizer they will actually be 1 5/8" which is a good thing but you will have to move rollers back to run them if you been running 1 1/2". I knew this when ordering them but everyone may not and this may have been posted before.
2007 LT70 Remote Station 62hp cat.
Percy
Thanks. I run the double hards but have wondered about those bi metals. What's your take on them?
My experience with extended run times mean earlier breakage. Of course this is with the double hards. If the company information is accurate, I may consider them.
mike_belben
Are there any bandsaw blades that can shrug off a nail strike and carry on?
Praise The Lord
Beavertooth
I was told by wood Mizer that they were getting a lot more flex life out of the bimetal verses the double hard but the guy did not say how many times more but he did tell me they were getting like 5 times the flex life out of the carbide blades verses the double hard. Both of them are made out of different material than the double hard. I got the info from Dough Hicks. He has been there a long time and seems to always know what's going on with things. I just got my bimetal blades and have not tried them yet. Have not had time to move my rollers back.
Bruno of NH
I just tried a cobalt band
They say you can get more life out of them.
I have herd good things about the woodmizer carbied @ $140 each i would hit a nail on the first log.
So I haven't bit on one yet.
Southside
Quote from: mike_belben on May 08, 2018, 10:51:07 AM
All depends on the nail and the approach angle.  Hit two the other day with a double hard and it sawed the rest of the cut just fine, has a few teeth that are burred over but should sharpen up OK.  Now hit a ring shank or a screw and it's game over.
White Oak Meadows
Beavertooth
 Woodmizer also told me they had a guy saw a half inch off the tip of his chain turner and managed to make it to the end of the log with bimetal blade. That says a lot for it just in the fact that it was able to saw it off. So there are probably a few nails out there that would not destroy a bimetal.
