I think I have a bad ignition coil on my lt30 onan
Started by Jeff, May 24, 2010, 10:55:44 AM
ronwood
LT40HG25 Woodmizer Sawmill
LX885 New Holland Skidsteer
Shotgun
Good job, Jeff! It sure is fun when a solution to a challenge like that works, isn't it?
Norm
Joined The Forestry Forum 5 days before 9/11.
You are quite resourceful, and so is the Forum  ;D.
fishpharmer
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
chet
Ain't nuttin' as good as good old resourcefullness.  8)  8)  8)  My only suggestion would be to trade out the steel machine screw and nuts for brass ones. Much less chance of a future corrosion problem.
Captain
Frank and I call it "yankee ingenuity"  ;D  I often love to marvel at it.  Real common at Frank's place.
Captain
Warbird
Quote from: Jeff on May 25, 2010, 10:54:23 AM
It lives!  It lives!  :) :)
Rock on!   smiley_guitarist  I was going to suggest cold solder but your method should be much stronger.
