Husky 55 rancher
Started by bandmiller2, January 29, 2013, 06:37:10 PM
A friend gave me a clean 55 no spark,disconnected the kill switch,still no spark.That model has a long history how do you tell when it was made to order the correct module.This is on the plate 967  05  29-00 and below that     02  2001295 anyone know how to break the code and the cheapest place to buy a ingnition module. Thanks Frank C.
celliott
Are you sure it's the coil that's bad? It could be a much simpler fix. Check all the wires for frays or cracks, check the grounds, spark plug wire\boot.
I had a husky that wouldn't shut off, checked the switch multiple times, checked the ground, and missed a fray right near the connector. Almost got upset with that saw  ;)
Chris Elliott
Clark 666C cable skidder
265rx clearing saw
Celliott,went over the saw checked for wire problems even removed the module and regapped it.As luck would have it I have a johnsy parts saw that has the same module I'll try that tomorrow. Frank C.
Drat and double drat the module in the parts saw was bad,I ordered one from Scott at chainsawr, an aftermarket replacement.At least I know why they quit using the parts saw,may be worth rebuilding. Frank C.
