General Forestry => Sawmills and Milling => Topic started by: ray299 on June 14, 2016, 05:07:50 PM
Title: blade lub system build... almost there...
Post by: ray299 on June 14, 2016, 05:07:50 PM
Don't know how to add pics to a post... Feel free to view my gallery. The last 6 or 6 photos I uploaded are the blade lubrication guide parts in the making. Just have to figure out how to mount themon the blade and put my shut off/adjustment valves in... Anyone have a link to a post handy on how this type of padded lub piece was mounted on others blades? I'm thinking weld it straight to the side of the blade guides....
Title: Re: blade lub system build... almost there...
Post by: Magicman on June 14, 2016, 05:23:08 PM
Put your curser in your reply where you want the picture to appear.  Click on the blue line below that says "Click here to add Photos to post".  Now find and click on the picture that you want to post, scroll down and click the blue line that says "Insert image in post", then OK.  The picture's address will be copied.  Click Preview and scroll up to see how your reply will appear.  Now click Post.
Post by: plowboyswr on June 14, 2016, 06:11:08 PM
 (https://forestryforum.com/gallery/albums/userpics/42965/IMG_20160614_120141347_HDR.jpg?easyrotate_cache=1465937946)
I will add one but the rest is up to you  ;D
Post by: ray299 on June 14, 2016, 06:47:13 PM
Quote from: Magicman on June 14, 2016, 05:23:08 PM
Thanks guys. I can't find the " insert image in post" but maybe that's because I'm doing this from my cell phone? I'll try again when I get to a computer. Also, looking for feedback on the lub guides... What do you guys think? Thanks for taking a look.
Post by: ray299 on June 14, 2016, 06:50:37 PM
https://forestryforum.com/gallery/displayimage.php?album=7274&pid=207279#top_display_media
Post by: ray299 on June 14, 2016, 06:52:09 PM
(https://forestryforum.com/gallery/albums/userpics/42965/IMG_20160614_114752095.jpg?easyrotate_cache=1465938193)
Post by: ray299 on June 14, 2016, 06:52:40 PM
Woo hoo! Got it!
Post by: ray299 on June 14, 2016, 06:54:06 PM
(https://forestryforum.com/gallery/albums/userpics/42965/IMG_20160614_120232636_HDR.jpg?easyrotate_cache=1465938008)
Post by: ray299 on June 14, 2016, 06:56:27 PM
(https://forestryforum.com/gallery/albums/userpics/42965/IMG_20160614_112329649_HDR.jpg?easyrotate_cache=1465937764)
Tapping for 1/4NPT
Post by: ray299 on June 14, 2016, 06:59:12 PM
(https://forestryforum.com/gallery/albums/userpics/42965/IMG_20160613_135450344.jpg?easyrotate_cache=1465937665)
1/2 steel with pocket milled for lub pad and bolt holes being tapped for 5/16x18 threads
Post by: Kbeitz on June 14, 2016, 07:11:22 PM
You can add more than one picture to a post. Just click on "insert image in post" as many time as you want.
Post by: Magicman on June 14, 2016, 07:25:11 PM
And you can add that picture's narrative below the picture's address.   :)
Post by: plowboyswr on June 14, 2016, 11:51:26 PM
 smiley_clapping ya got it now.
Post by: fishfighter on June 15, 2016, 05:26:52 AM
Is it me or I'm I seeing the blades driving the wrong way?
Post by: ray299 on June 15, 2016, 10:43:15 AM
Quote from: fishfighter on June 15, 2016, 05:26:52 AM
I guess that depends on the side you want to stand on... Standing behind the saw head my log will be fixed to the left side and the blade will be moving from left to right throwing the dust away from me...
Post by: Ljohnsaw on June 15, 2016, 11:35:51 AM
No, I think Fish was referring to you are lubing AFTER you went through the cut.  I know that Tim of Cooks likes to do it that way.  Cleans up the blade before it hits the drive wheel and prevents sawdust from building up on the drive wheel.  I think most here add the lube before entering the log so it slips through easier.
Post by: fishfighter on June 15, 2016, 11:44:19 AM
Really both. ;D
Post by: Magicman on June 15, 2016, 12:32:47 PM
Whichever it is, you want the powered wheel to be pulling the blade through the log, not pushing it.
Post by: kelLOGg on June 15, 2016, 01:30:55 PM
Looks similar to mine. I lube before and after. Worked well for years.
Bob
Post by: fishfighter on June 15, 2016, 01:37:54 PM
Quote from: Magicman on June 15, 2016, 12:32:47 PM
That is what I was thinking. ;D
Post by: ray299 on June 16, 2016, 07:27:48 AM
Quote from: ljohnsaw on June 15, 2016, 11:35:51 AM
Ah, yes, I made a lube guide for each side. And yes, the drive wheel is pulling the blade through. The questions are good, keep up the analysis of my photos. I'm doing this strictly from looking at other peoples designs. I've never actually seen a band saw mill in person so this will be pretty exciting if it works. Lol
Post by: fishfighter on June 16, 2016, 07:35:04 AM
What size motor you using? I found that to much lube chokes up the blade. Half the time I don't even use lube. It's like a touch and go thing. Most depends on what I'm sawing and how the blade is acting. My mill only has a 9.5hp motor.
Post by: ray299 on June 16, 2016, 10:52:21 AM
Quote from: fishfighter on June 16, 2016, 07:35:04 AM
I'm using a brand new 10 hp briggs... for now. I was planning on upgrading if it needed. for lub I'm planning on using a diesel fuel/transmission oil mix. I'll have a shut off at the tank and each lub unit will have an adjustor.
Post by: fishfighter on June 16, 2016, 05:33:06 PM
What kind of logs? SYP here in the south has all kinds of pitch(sap). I use water and Dawn dish soap. I don't think I would like the smell of what you using. Yes, I had read it here that people use it, but I found that what I use is just fine.
Post by: ray299 on June 16, 2016, 08:49:44 PM
Quote from: fishfighter on June 16, 2016, 05:33:06 PM
I'll be cutting all kinds but I have lots of ash and oak stacked up and ready... I chose that mixture to reduce rust. O can always change over to water/soap if I don't like the smell I guess...
