TJ lever handles
Started by mf40diesel, March 12, 2017, 08:43:54 AM
mf40diesel
Anyone know of a set of levers that may be somewhere for sale of the old style hydraulic controls on a TJ skidder?
I have the kind that simply pivots, there isn't the "chain link" detachable section.
Mine are wicked worn out and egg shaped. Or maybe a set of bushes?
John Deere 5055e, mfwd. Farmi JL306 Winch. Timberjack 225 Skidder. Splitfire splitter & Stihl saws.
North River Energy
If you're referring to the tab where the lever pulls on the valve spool, I've had good luck welding up the hole and drilling another. Use a flat piece of copper as a backer to prevent welding the part to the work table.
If it's cast, use brazing rod.
mf40diesel
I have thought the same thing with regards to welding them up and drilling them out.
Which will likely be what I end up doing.
Thank you
