Author Topic: Workshop First Aid  (Read 1293 times)
Offline firefighter ontheside
  • I like trees.
Re: Workshop First Aid
« Reply #20 on: September 27, 2021, 03:58:01 PM »
As Doc said, the goal is stop the bleeding and not just to catch it.  If you apply a bandage and it soaks thru, do not replace it.  Go over the top with more bandaging.  As blood begins to clot in the original bandage it will not soak thru as easily.
With the kinds of injuries we can cause to ourselves with sawmills and wood shops, a tourniquet is a must.  If you search tourniquet you will find many suitable tourniquets with a windlass that you wind which applies pressure.  Practice putting it on with each hand by itself as you may have to do that if you injure an arm or hand.  After you put it on for real due to an injury, do not take it off.  As Doc said, some training is good.  Not every injury needs a tourniquet.  Direct pressure may be all it takes.
Another very useful dressing is known as an Israeli bandage, which can also be had on Amazon.  Its a good dressing that can apply pressure.  As with the tourniquet, some practice is warranted so you will know how to use it if need be.  Learning to use it while you're bleeding would be less than fun.
We teach stop the bleed here at the firehouse.  Its a good program.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
Kawasaki Mule 4010
Offline Texas Ranger
  • Forester
  • Texan, by God and by choice.
« Reply #21 on: September 27, 2021, 05:30:31 PM »
Army said stop the bleeding, protect the wound, and treat for shock till help arrives
  • Forester
« Reply #22 on: September 27, 2021, 05:33:33 PM »
Something often overlooked for sawmill safety equipment is an eyewash station.  I had someone get sawdust in their eye and all we had was bottles of water.  I bought a couple of portable units but found out that the shelf life is only 2-3 years and, fortunately, I haven't needed them.  I am considering eyewash cups that you can use with distilled water the next time.  Hey Doc(s), are those effective?
I keep one of the plastic squirt nasal wash bottles full of a saline solution for eye wash.  Hold eye lids open and squirt with saline.  Helps a bunch.
Offline doc henderson
« Reply #23 on: September 27, 2021, 05:53:36 PM »
Tom, garden hose is ok, but cold water can be uncomfortable.  if i had to at home i would jump in the shower.  you can use flush syringes if you have access.  they  sell 1 or 2 oz bottle of eye wash.  eyeballs are something that people tend to be skittish about, so a cup that you push on your face may be helpful for some.
Offline beenthere
« Reply #24 on: September 27, 2021, 09:14:05 PM »
Too late, already got my finger in the table saw with saw stop.  Cutting chicken coop stands when my glove started to unravel about 8 inches from the blade... glove started to go towards the blade and I pulled so hard that I lifted the table saw up... well it hit my thumb and the blade braked.  Could have been very bad..  Took some bone fragments out.. was able to stop the bleeding with liposomal lecithin (cleaner then quick-clot).  Slow drip of serum but hey, I'm thankful I still have my thumb.
A good and important rule around saw blades, is to not (like never) wear gloves.
Sorry to see that injured thumb.
  • I like trees.
« Reply #25 on: September 28, 2021, 07:26:54 AM »
I never, like ever, wear gloves in my shop.  I'd rather have splinters than get my hand pulled into a saw.
With my sawstop, Its best for my finger to contact the blade instead of a glove.  I've heard of people wearing rubber gloves that fit tight.  That would probably be safe.  Might prevent some splinters, give some extra grip, but not strong enough to pull hand into blade.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
Kawasaki Mule 4010
Offline WDH
  • Forester
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #26 on: September 28, 2021, 09:19:51 AM »
Dont wear gloves when using the jointer.  Just saying for a friend :) :).
Woodmizer LT40HDD35, John Deere 2155, Kubota M5-111, Nyle L53 Dehumidification Kiln, and a passion for all things with leafs, twigs, and bark.  hamsleyhardwood.com
Offline bannerd
  • Madman
« Reply #27 on: September 28, 2021, 11:07:10 AM »
Without the saw stop I can tell you... my hand would be a lot worse.  However it works, it took the blade away and that is what I ended up with.
I thought about it and honestly the most danger was not having a clear head.  I've been doing way more thinking than I normally do and honestly that is the worst thing to have when doing any wood work.
Offline WDH
  • Forester
« Reply #28 on: September 28, 2021, 02:01:15 PM »
That Sawstop saved you from catastrophic injury.
Offline kantuckid
« Reply #29 on: October 22, 2021, 02:21:33 PM »
Here's a more mundane woodshop tip: Get a hold of one of those first aid kit splinter removers. They are in most all kits. I stole mine from my HS job years back as there were a bunch in the kit anyway. They are a small SS pointed thingy that's ideal for splinter removal. Works better than a needle by far! I keep one taped to a toolbox at all times and another at the house. Pops em right out and will help cut in some on the bad ones!
Another tip- That sticky gauze mesh like they use to hold gauze on an injection site, etc. works great to keep blood off of your woodworking projects and is also useful when sanding on the lathe. I talked the blood donation lady out of some when she asked me what size T-shirt I wanted last donation.
I once toured a nearby cabinet factory and many/most of the workers there were using it if they were sanding. I even saw it in use today in a video of handmade suede slippers showing a hand stitching operation. It's also useful to act as the bandaid  itself when your at work.
 R.e. gloves- I am currently T&G'ing 2x6's and do wear gloves using my router table. The bit throws vicious chips which become ballistic missiles that play havoc with your hands. In fact,  I also wear a sweatshirt as my forearms were a mess! Senior skin doesn't handle impacts so well and arms looked like Id been tortured.
I did see some gloves at HD the other day that will be my next bunch. They are the coated thinnish ones that are black with blue trim.
  • I like trees.
« Reply #30 on: October 26, 2021, 08:03:33 PM »
I got some splinter removers from @doc henderson at the Pig Roast.  Havent used them yet, but I'm sure I'll get the opportunity soon.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
Kawasaki Mule 4010
Offline Dan_Shade
  • I don't want to edit my profile!
    • Shade Custom Sawing
« Reply #31 on: October 26, 2021, 09:02:44 PM »
What type are they? I have a bunch of splinter out, they work well.
lots of dull bands and chains
Host a timberframe workshop?Updated-Changed to log builder workshop
Started by fred in montana on Timber Framing/Log construction
Last post February 02, 2011, 07:52:57 PM
by fred in montana
My New Workshop (not really.....)
Started by Phorester on General Woodworking
Last post October 27, 2021, 05:09:04 PM
by Tom King
KU workshop
Started by Jim_Rogers on Timber Framing/Log construction
Last post September 11, 2015, 09:39:39 AM
by Jim_Rogers
NE workshop
Last post September 13, 2015, 01:31:46 AM
by Carpenter
