Western Maryland Loggers and Forestry Field Day and Equipment Show
Started by MartyParsons, June 05, 2005, 09:48:49 PM
MartyParsons
Hi,
Friday June 10 2005 - noon to 8 pm
Saturday June 11 2005 8 am to 4 pm
http://mdforests.org
$10 general admission
13 south of I-68 at exit 14 on route 219 McHenry MD
We will have the new LT10 mill at the show.
Marty
Bibbyman
Quote from: MartyParsons on June 05, 2005, 09:48:49 PM
Marty
What LT10?  When did that happen?  Knowbody told me about an LT10. smiley_headscratch
I think my WM buddies are letting me down.. >:(
Sawing since '94
I saw it! I touched it! Got a first hand tour and fill in from Dave Mann of Wood-Mizer. Watched it saw.  Nice rig.  I suppose you want to know more then that?  :D
Ya know Bib, with all the imposters running around out there now they probably thought they had already told ya.  :D
MartyParsons
Do you want some pictures? I cant believe there has not been any posts on it yet.
I picked one up at the Sawlex show. I think they are going to work good. I have a CD with all pictures. I am not sure I know how to post them but am willing to try.
Marty
Don R
where does the LT10 fit in. Is it smaller than the 15, a replacement for it, or what.
Its smaller, and really very very portable and storable. It can all be folded up and take the space next to a garage wall not much bigger then what a bicycle would take.
GareyD
I took a couple of pictures of the LT 10...woulda brought one home but them Florida boys wouldn't give up their seats in the truck :D :D :D
The statistics on sanity are that one out of every four persons is suffering from some sort of mental illness. Think of your three best friends, if they're okay, then it's you.
In the first photo, if you look to the left of the LT10 sign, you can see one in the stowed position. It dont take up much more room then you see there.
Bibbyman
Now that we got pictures.  We got questions?
Is it a "TWO POSTER" or does it have a cantilever head like the LT15?
Looks like it comes with angle iron frame that bolts to some wooden runners. ???
What size band wheels/blade lenght?
What size motor?
What's the price?
I just may want one to set up on my front porch!  8)
Sawing since '94
GareyD
2 Poster
Yep
Fergot to ask and the web site don't say
What size motor?
7.8 hp
What's the price?
$3,995
I'm thinkin' about setting one just inside the double doors on my woodshop  ;D
MartyParsons
[quoteIs it a "TWO POSTER" or does it have a cantilever head like the LT15? Two Post
Handles 24 " Dia. Logs and 11' Long, extentions available no limit to length
Looks like it comes with angle iron frame that bolts to some wooden runners. You supply the wood 4x6 cant. You can use the saw to saw these if needed.
What size band wheels/blade lenght?19" wheels ( you can use your B-57 belt on one side any way.) length 144" We were using the Double Hard Blade or the Silver Tip .042 thickness.
What size motor? 7.8 hp pressure lube system
Rated at 55-100 Bd/ft per hour
Hinged covers like the LT70! Real Nice!  8)
Blade guide rollers are the same as the big mills , you can even put the guide block system if you need to! It is designed for this.  ???
What's the price? $3995.00
Quote
Bibbyman
Is ACCUSET an option??   ;D
How about a 5hp single phase motor?
Sawing since '94
