Just got 30" alaskan mill for christmas, chain recommendations please
Started by ontario026, January 01, 2006, 01:27:09 AM
ontario026
I just got a 30" alaskan mill for christmas, I already have a new 30" oregon bar (3/8" x .63 if I remember off hand...)  The saw is an 044 that is muffler modded,  I know that it is going to be somewhat underpowered, but I am not looking for high production, just to rip up a few logs here and there for material for my amateur woodworking...
I generally always run chisel chain on my saws, and from what I have seen of ripping chains, correct me if I am wrong, but they are always based on chisel chains, correct?
Seeing that I am going to be running a "less than ideal" sized saw should I be looking at running a full skip chain to minimize drag through the wood?
Any opinions regarding chain suggestions would be greatly appreciated, please "go buy a bigger saw" suggestions, since unfortunatley that is not an option at the moment...
Thanks guys
Matthew
ontario026
I probably should add I mainly plan on dicing up hardwood,  as for size of wood, mostly whatever I can get my hands on, but I would estimate most should be probably less than approx 20-24"
Matthew
Minnesota_boy
Each cutter removing wood requires x amount of horsepower to pull it through.  Fewer cutters will help.
leweee
Mattew....sharpen some of that full comp.chisel chain at 90 degree top plate angle & 55 degree hook angle....20" is about all thats left after you mount the alaskan on that bar....full comp should work fine ground this way. Try it on an old chain & let us know how it works....Rakers set at .025" ;D
clyde
