Woodmizer Battery Light and Alternator Belt
Started by ncsawyer, May 15, 2015, 09:31:28 PM
ncsawyer
My mill is practically brand new and only has 15 hours on it.  I noticed this evening that the battery light flashes every time I disengage any of the hydraulic levers.  It also flashes sometimes when I release the back and forth control for the head after traveling back to the front of the mill after a cut.
My old Woodmizer didn't have an alternator, it charged by a stator (like a lawn mower), so I don't know if it is normal for the battery light to flash when doing certain functions with the mill.  Have any of the other Woodmizer owners noticed this with their mill?
I also noticed this evening that my alternator belt will be lucky if it makes it  until I get the rest of the order I am working on finished up tomorrow morning.  This is the second alternator belt I have been through in 15 hours.  We worked for half a day at the dealership when I bought the mill the correctly align the drive pulley.  It shredded the first belt in about 10 minutes.  We slid the drive pulley as close to the engine as possible to get it to line up with the alternator, I guess it's still not lined up right, but I don't think there is any more adjustment in the drive pulley. It's as far as it will go in that direction and it looks like it needs to go a little bit more to get the alternator and drive pulley lined up.
2015 Wood-Mizer LT40DD35
Woodmaster 718 planer
Ford 445 Skip Loader
Chuck White
Is the tension correct on the alternator belt?
The biggest issue is alignment.
There has to be something you can do to get "near" perfect alignment of the pulleys!
flatrock58
ncsawyer
I have a 2001 WM LT40 super I bought last summer.  My battery light blinks when I run the motors all the time.  It has not caused me any problems that I can see but I am not sure if it is normal.  I guess it could be a ground problem.  My alternator belt is fine and the battery stays charged.
2001 LT40 Super Kubota 42
6' extension
resaw attachment
CBN Sharpener
Cooks Dual Tooth Setter
Solar Kiln
Ox
Could it be the light sensing the momentary hesitation of the voltage regulator in the alternator as it switches between different charge rates?
drobertson
Seen it before, battery connections and a good ground on the under rail.  Now the alternator is a different issue, if not charging then that makes a little bit of sense too.    Simple fix,
MartyParsons
Hello,
That alternator belt needs to be aligned correctly. You should be able to tell. One side of the belt will pull off if not aligned.  We had the same issue here with that same diesel. I have been checking them ever since and have not had any more issues. Yanmar D35
I will try to post a picture of the pulley and post it.
Marty
