Porch Decking & Overloaded Trailer
Started by Magicman, March 13, 2024, 05:15:59 PM
Both roofing contractors have been here, measured, made notes, and will furnish me with an estimate.  One would be all stick construction and the other would be all metal construction.  We shall see but I would prefer the all metal version.  I just hope that the estimates do not exceed my $$.
61 is soon.
That may sound good on the surface but it would not an option with either of these contractors although we did talk sawmilling a bit and one of them may need some old timbers resawed.  They have materials to buy and labor to pay and I doubt that either of them would be interested in a whack of 2X4's.   :wink_2:
61 is soon.
Southside
MM I think we may have a Palindromic sort of relationship here, for me 16 is coming.   ffwave
I finished laying this second tier on March 21.
It was laid tight with absolutely no gap between the kiln dried pressure treated 2X6's.
I took this picture this morning which shows:
Between an eight to a quarter inch spacing between the boards.  I am pleased.
An odd thing that I found while handling the 2X6's was:
I noticed that this one had a plastic plug indicating that the treatment facility had taken a core sample.  I suppose that they were verifying the pressure treatment penetration depth.
The plug was wood colored and you can see where I scratched the surface.
MM, kiln dried after treatment by you?  or just standard lumber, kiln dried and then pressure treated.  The saturation, weight and MC of PT wood varies greatly.  It seems like a good idea for more refined building with it, to get it down to a similar lower MC before building.  avoid the big gaps.
JD Guy
Quote from: Magicman on April 16, 2024, 09:29:56 AMI finished laying this second tier on March 21.
Thanks for the pics, especially those of the boards you butted up during installation. I know what I'm going to do when I replace my deck now ffwave
Very nice by the way!
Quote from: doc henderson on April 16, 2024, 09:44:44 AMor just standard lumber, kiln dried and then pressure treated
Yes, Dried and then placed into the chamber where a vacuum is pulled, immersed in the chemicals and then pressurized.
This lumber came out of the treatment plant the morning before I picked it up that afternoon.  It was soaking dripping wet.  I picked the lumber up on March 13th and had it all laid by March 27th.  I know, I'm slow but there ain't but one of me.  :wacky:
Another page in this ongoing deck/porch saga.  Yesterday the two trees that are destined to become my railing came down.
My tree service guy uses an "Easy Lift" which will reach an incredibly 87' and will maneuver into tight spots and also can be used when the ground is quite wet as mine is.
Here it is set up and ready for action.  The trunks of the two trees to be removed can be seen in the background immediately above the bucket.  They are both on the far side of the woodshed.
He has now removed the lower limbs and is working his way up the nearest tree.  As you can see both trees leaned heavily over my shop and wood shed.
Just moving along and removing limbs as he gets to them.
This was a fun experience watching him work.
Taking the limbs out of the top of the near tree.  He is almost at his max reach of 87' here.
Lowering a limb with his hydraulically controlled winch.
The limbs are all on the ground and he is placing bull lines in both trees.
The bull line is tightened on the near tree.
 That first tree is on the ground so it is on to the second tree.
Success.  Both trees are down and the Pine tree that was not even visible in the first pictures is now the only thing standing.
As a side note, the Cherrybark Oak that I was counting on to provide most of my railing lumber was hollow and no good.  Thankfully the Post Oak is solid, but it will have to dry out before I can either skid it out or take the sawmill to it.  The porch railing will have to wait a bit more.
