2011 New Year Cleanup!
Started by Bibbyman, January 02, 2011, 10:53:24 AM
Bibbyman
I have a lot of pictures on the Forum.  And a lot of albums.  But a couple are rather big and the subjects varied.  So I decided to make a couple more albums and go through at least the biggest one and sort things out. I reduced it from well over 200 to just over 100.  I could still work at it some more.  I have some albums that only have a few pictures that could be put another album and then done away with.
In any case,  I hope I can at least find back the pictures I tend to look for and re-use.
Now I need to go through my old messages and delete, delete, delete.
Sawing since '94
Mooseherder
I need to clean my desk and garage today. ::)
Took the Christmas Tree outside yesterday.
What a mess that was. :D
Please don't anyone misinterpret Bibbyman's post as that he is deleting posts and photos from the forum. DON'T DO THAT!
Sounds like Bibby is worried that Mary is going to get on the forum.   ::) ::)
Bibbyman
Quote from: Jeff on January 02, 2011, 11:10:40 AM
Yes, yes!  Don't do that!..  I was just moving them around in the albums.
I need to clean up my old messages though.  maybe in the middle of the night when I'm up to...  feed the fire and let out the dowg.
Sawing since '94
Bibbyman
My inbox says 0 but I kept 3 ...
The easiest way I found to delete messages is to check the box in the header line to select all for delete.  Then I go through and scan any I want to keep and uncheck them.  Then Delete Slected.
Good for another year  ;)
Sawing since '94
You need to do that on your outbox too.
Bibbyman
Quote from: Tom on January 02, 2011, 07:50:21 PM
Outbox?  Didn't know I had an outbox.   smiley_headscratch
Went and looked and my outbox was empty.  So I guess I've never used it.  smiley_heh_heh
Sawing since '94
You have to go into your Personal Message Options in your profile to enable saved outgoing messages.
Bibbyman
Quote from: Jeff on January 02, 2011, 09:35:51 PM
I guess if I ain't needed it all this time,  I'll just not need it now.   ::)
Sawing since '94
