Hello all,
I know everyone is out sawing on this beautiful day and I'm sitting in front of my computer thinking about building a mill!
I'm not trying to start a war here, but I see lots of differing options/opinions on band wheel types: car tires, v-belt pulleys and steel wheels with no tire or between the wheel and the blade. On the steel wheel with no tire, isn't the blade much more likely to break if something gets between the blade and the wheel? I know Cook's uses this setup, but there's nothing to "give" if this happens.
Opinions/experience with the band on steel type setup?
I've never run a mill, so how likely is it that a chunk of whatever gets between the blade and wheel?
We had that happen 2 times, that we know of. We use boat trailer tires and one time, it started to burn the rubber. The other time, it went right on around and out the housing. Might be something to the theory of "give" of an inflated tire :o ;) ;) ;D ;D
chisel,
The major manufactures of band mills with narrow bands that run metal to metal band wheels tension them either with springs or with air bladders. This helps some to reduce the shock of getting a chunk of wood between the blade and the wheel, but the mass of the wheel and bearings assy. is still a factor.
FDH,
Seems like the trailer tires might be the easiest, cheapest, and most forgiving, esp. for a newbie like me. :)
D Frederick,
I didn't know about the air bladder system as you described, although I didn't think about it, my Delta bandsaw is tensioned w/ a spring.
I was looking at the Linn Lumber site (I have his video where he assembles a saw head) and saw the "hydraulic blade tensioner" that Gary uses. About halfway down this page:
http://www.linnlumber.com/sawmill_parts.html
It has a manual screw pump and cylinder. Seems a bit steep at $400, but I've searched the web for hours and haven't found anything similar, but I like the idea of the hydraulic tensioning...I thought it would help me see if the band was getting too hot, and I could replicate the settings when installing a new blade.
Thanks for your all's thoughts.
It appears the cooke screw pump is or is patterned after one from a hydraulic bearing/pulley separator.
What you do so that nothing will get between the wheel and the blade is put a piece of metal in front of the plade guide and just a hair off the blade and that makes it so that nothing will get between the blade and the wheel.
As for tensioning the blade on trailer tires it is not a problem cause the tires don't let the blade slip like it would on metal to metal. :)
And another thing is you don't have to worry about the cown in trailer tires like you do with steel wheels.
We have the metal shield Rod talks about. It is a small wire brush that wipes the build-up from the blade, before it gets mashed TO the blade from pressure against the tire. It STILL had 2 different chunks get between the tire and blade.
Highway tires ARE already crowned.
chisel,
The using a trailer tire for a band wheel still has some problems: it must be perfectly round or it will cause blade whip, it must be perfectly balanced or there will be vibration, it must have a crown or the blade will not track. it doesn't like diesel to get pitch off.
I think a mill made with tires will not have the re-sale value of a mill with metal wheels.
The factory made narrow band mills all use metal bandwheels but one, so you are looking at about 50 to 1 ratio, if tires were so good, you would see more of them being sold.
The hydraulic tensioning allows the blade to be set up to the same tension each time, regardless of difference in blade length. The mills with springs have a calibrated pointer to set the correct tension.
In another thread I mentioned that I bought some 24" aluminum band wheels with 1 1/2" wide rims. I think if I put some tires on them (from Suffolk, Carter Prod., e.g.), that they'd work ok. The ones from Carter Products are 3/16" thick.
My current plan is to use hydraulic tensioning with these wheels. I'll try to post a side view of the wheel below.
https://forestryforum.com/images/03_21_04/index.php?image=24inchwheelsideview.jpg
DanG, this is the second time I've posted a pic and the pic doesn't show up in my post, just the URL.
I followed the steps to posting a pic (thought I did anyway), but I've never seen "the red verbiage on the upper left of the returned screen."
What am I missing?
I agree with D,I think the steel wheel mills will sale for more money when you resale.
But maybe thats cause they cost more then the trailer tires.But that doesn't mean they are better.I have never heard of anyone who has every had any trouble with using trailer ties for band wheels. also you can buy the bearings at NAPA,and new tires at the tire store,but I have never heard of anyone wearing out a set of tires tho.
I believe the reason the big companies don't use them is cause they can't make enough profit of the idea.
And for the blade guides juse put 2 bearing side by side on the top and bottom of the blade and 1 on the back with a nut and bold though them.You can get the bearings at NAPA part # ASK VV6300
I use tires for my home built mill. I put them on the mill and spun them and made a lathe type setup to cut them to perfect round, then had them balanced. they work very well for me and cost me $10 to balance, i had them laying around. I have many pics here in the " The bandmill that I built " thread.
Never having run a small band , My opinion would probably be flawed but on the bandsaws I have ran which have 7' and larger dia. wheels its steel to steel. Very little problem with chunks in the wheels , never had one come off the wheels for sure . I think the tires would be the best and least expensive way to go, I dont forsee all the problems that some ppl seem to see in this setup. I have been sawing and millwrighting on these things for about 28 yrs. and I think (uh oh ! ;D) that most anybody with a little horsesene, and some southern engineering should be able to make the tires work. My $ 0.02
Here is how my blade guides are made
http://www.woodweb.com/images_forums_public/sawdry/040606153313.JPG
http://www.woodweb.com/images_forums_public/sawdry/040606154445.jpg
Nice tires.
Good pics Rod. Thanks.
Chisel
Been sawing nearly two and one-half years with steel band wheels and had no problems from it. Only time a band has come off was when tried to back it up without raising the head. ;D ;D I have 26 in. band wheels, and the blade is tensioned by a spring so I guess there would be "give" to it if something should get under the band on the wheel, but I have never had that happen. The roller guide on the "out" side of the log/cant has a shield and bottom control that would not let anything through large enough to cause a problem on the band wheel. I have occasionally not run the drip heavy enough when sawing pine, allowing build-up on the wheel, making the blade move forward a little. I simply turned up the drip and it cleans the wheels and the blade moves back to where it should run.
Never had any experience with rubber tires/trailer tires, other than my shop band saw, but don't think that is a good comparison to the bandsaw mill.
Good luck with whatever you choose!
Eddie
Hey chisel, Gipper, good to see some Ky boys on here,thought i was the only one :D
chisel my wheels are V-belt style but like gipper said mine has a big spring on it.
I had some chunks get stuck under the belt and the spring started moving in and out badly but didnt hurt the blade, just shut it down cleaned it out and started again.
If you never ran a bandsaw you are welcome to come up and run mine if you want, all i got is a few oaks and some cedar to saw,ill let you saw the cedar ;)
Hey Gipper and steveo, I was looking at the members map and there's a few more of us Ky boys than just the three of us. The rest of them must be out running their mill!
Thanks for both of your descriptions of your mill.
steveo, I may take you up on your generous offer. I'd be glad to offer my labor for a few pointers (and the opportunity to take pics of your mill). I have a full ww shop but have never run a bandmill, just seen some run by someone else.
Chisel
Though we are in the same state, there's a lot of miles between us, but like steveo, if you are up this way look me up and we will saw a log or two and talk sawdust for a while. :D (I'm only about 7 hours or so east of you.) You can see what my bandwheels and roller guides - actually the entire mill - looks like by visiting the Cook website. www.cookssaw.com
Stevo_1 Did you escape all the bad storms in your area last week without any damage? I was lucky, but some of my neighbors weren't. Couple of counties around us were hit even harder than we were. Lot of nice trees came down. Here the first thing most people think of is firewood. I was called about one nice Maple, but by the time I got there the best logs had been cut to firewood length. >:(
Gipper we had some bad storms come through but we got lucky and only lost a few limbs here and there. My uncle lives a few miles away and he got hit good,him and his neighbors lost some trees,his neighbor lost a carport, it blew out in someones field,no major damage and nobody got hurt.
Im thinking about running an add in the paper every spring to let people know i will clean up those trees to get the logs off of em,too many get chopped up into firewood. >:(
Chisel we can set up a date.Maybe send me a PM we can figure something out.After the 4th would be good for me,i got some stuff needs doing next few weekends.
Gipper,
I have the Cook's demo video and I have visited their site many times. Which mill do you have? 7 hrs. is a long way to make sawdust, but I'll think about it! Thanks for the offer.
steveo, after the 4th probably works for me. I have a sister in Louisville so it'd be great if I could visit you both in the same day. I'll send you a pm when I get my schedule figured out.
Chisel
I have the Accu-Trac 36 hydraulic mill.
Eddie
Kind of late replying to this one.
My Logmaster mill runs crowned steel bandwheels. The tensioning is with a hydraulic system with no spring tension or give. There is a blade scraper just before the guide on the outgoing side. So far nothing seems to have stuck to the blade & gone around the wheel. I suppose you never know though.
QuoteKind of late replying to this one.
MrMoo,
Better late than never! :D
I'll add a blade scraper to my list of "options" on the mill I have in my head (and soon to be reality?). :)
Thanks for the info.
I posted on this thread waaay back. Maybe I should clarify a little. We saw logs that have loose chunks falling off (Pecky Cypress) that CAN get bounced around and HAVE gotten caught between the housing and the blade AND the wheel-tire.
We have a wire brush-scraper mounted AFTER the fixed blade guide, so, it's possible that the pieces did NOT actually go through the guide, but, bounced around inside the housing and got jammed into the blade and tire.
Every once in a while, we get a loud thump and see pieces fall out the top of the blade housing that's between the two wheels. Every piece does NOT go out the chute.
