cook's plung sharpner
Started by wscott, November 15, 2007, 02:43:13 PM
wscott
saw this on youtube and though others might like to see his. very simple
   http://youtube.com/user/alonsolcor
You should always marry a ugly girl, when she leaves you, you want feel so bad.
customsawyer
I just bought a sharpener from cooks yesterday and it is a little different than that one.
www.thecustomsawyer.com
LeeB
Surely this is the wrong cam or something else is badly amiss. What a shame to see a brand new blade ruined like that.
Percy
That looks like a CBN grinding wheel similar to the one I have on my WM sharpener. They plunge the whole profile at the same time. The wheel has to match the blade teeth  near perfectly. Mine uses oil for a lubricant instead of water. I have had the same stone on for a year and a half and its still working great. I average about 7 sharpenings per working day. The thing is very consistant and never blues the steel and leaves virtually no burr. I dont know how long that wheel would last with water lube.
CBN sharpeners have many advantages over  the regular type of sharpeners and a few disadvantages as well IMHO.
Advantages
No constant profiling the grinding wheel
No blueing the blade gullet
No burrs
Very  sharp consistant grind throuout the whole blade
Much quicker setup
Disadvantages
Wheel cost is about $300.00 but probably lasts as long as about 20 regular stones(jury    still out on that one)
Blade profile has to match the grinding wheel(I use a WM wheel so I MUST use WM blades )
Switching between any different profile(10 degree/13 degree/9 degree/4 degree) requires a stone for each profile. Could get pricey if you arnt happy with one setup.
Ive had mine for 18 months now and I could never go back.
Brad_S.
That must be a Frankensharpener modified by someone who doesn't know how to sharpen blades. For those who don't sharpen their own blades, the rock should come down on the face of the tooth as shown in the video, but it should then rake the gullet and travel up the back of the tooth and across the tip as it rises up.
bigmillman
I did not know that Cooks made a sharpener like that.  I have a Cat Claw (I believe that's right) that does a good job.  I sharpen a lot of blades with the Blue (?) stone that comes from cooks.  As stated earlier, once you start grinding you better keep the blade moving or you will blue the steel...I've been down that road too.  I use 3 different kinds of blades and sure would hate to have to buy 3 different grinding wheels at $300.00 each!
This is my first post on this forum, sure have enjoyed just checkin it out so far!
Stacey Freeman
Freeman's Mill
Brad_S.
Welcome to the Forestry Forum bigmillman! 8)
I am sure that that is not a Cook's sharpener, but rather a homemade unit based roughly on a Cook design. I too have one of their Cat Claw sharpeners and receive their mailings regularly and I have never seen anything quite like that in their literature.
logwalker
Whether that is a Cook's original or not, it is a very good piece of engineering. Without a chance to inspect the finished grind it is impossible to say but but looks to be doing a good job at a very high rate of speed. Anybody privy to more info about the grinder or it's builder? Joe
Let's all be careful out there tomorrow. Lt40hd, 22' Kenworth Flatbed rollback dump, MM45B Mitsubishi trackhoe, Clark5000lb Forklift, Kubota L2850 tractor
Kcwoodbutcher
I grind mine the same way only on a modified radial arm saw and a blade holding/ indexing jig. I use a silicon oxide wheel that I dress to the profile I want ( that's where the real work is ). The profile lasts quite a while with just a little touching up every once in a while. If I change the angle I also have to change the profile of the rest of the stone a little. You can sharpen as fast as you can index and pull the blade through the jig. Now I just have to make a setter.
My job is to do everything nobody else felt like doing today
ronwood
kcwoodbutcher,
Would you happen to have any pictures of your setup?
Ron
Sawing part time mostly urban logs -St. Louis/Warrenton, Mo.
LT40HG25 Woodmizer Sawmill
LX885 New Holland Skidsteer
Brian_Rhoad
A chainsaw chain sharpener can be modified to do the same thing. I had used one modified to use a 3/4" thick grinding wheel to make a plung grind on blades. It takes a different wheel for each blade style and hook angle. Also a different wheel for tooth pitch. I could get the blades very sharp, but my Dino sharpeners are much nicer!
Kcwoodbutcher
I'll take a pic tomorrow and post.  By the way,it was aluminum oxide not silcone.
Faron
Percy,where did you get your stone?  Did I understand correctly that you are using it on a Woodmizer sharpener?  If so, did you have to get a different cam so it plunges down and picks right back up?  I can see that would be a very good setup.
Democracy is two wolves and a lamb voting on what to have for dinner.  Liberty is a well armed lamb contesting the vote. - Ben Franklin
wscott
 have e-mail  the person that put the video on youtube and here is the reply
  "we make this machine in Costa Rica and sell them in South and Central America, the water is a special coolant for tools, we use and sell Simonds red streak saws (they are the best, by far), the aproximate cost of the machine is $ 2300, it uses a CBN wheel instead of a grinding wheel, the shape of the wheel has the shape of the tooth profile, so it reproduces the shape, leaving and excelent sharp edge."
Kcwoodbutcher
Ronwood here's a pic of the sharpener. Pretty crude and simple but it works well.
LeeB
Obviously I need to watch the vid again. Thought I saw just the face being ground and a step in the gullet.
ronwood
Kcwoodbutcher,
Thanks for the pics.  Can you adjust the depth of the cut easily?
Ron
Kcwoodbutcher
The depth of cut is done using the height adjustment on the saw very carefully. It's pretty coarse adjustment but once it's set you 'll not have to mess with it much. The indexing pin (bolt ) is slightly bent so rotating it a little gives you horizontal adjustment ( or you can tap it with a hammer like I do ). I just shave a few thousandths of each time I sharpen a blade. The wheel is a one inch wheel to get the full length of cut on a 7/8 pitch band at an angle. Check the arbor length on your saw, it just barely makes it on mine.
Percy
Quote from: Faron on November 17, 2007, 05:09:59 AM
Heya Faron
I got my CBN wheel and cam/splashguards which came in a upgrade kit from Woodmizer. Took a couple of hours to install. The cam is very simple compared to the regular cam as all it has to do is drop the head momentarily, then lift it quickly before the foot pushes the blade.  There is a rather comprehensive oil delivery system  for the wheel and alot of splash guards to keep the oil contained. They work quite well. The whole system is very good. I dont know if the upgrade kit is available to U.S. customers as they have the RESHARP option not available anywhere else in the world.
I'll take some pics tomorrow and postem...
later
Percy
gmmills
 Percy,
    The kit is still not available to us in the US.  :'( :'(   I 've been talking to many WM techs about the possibility of them offering the kit here.  Still no go.  I know of at least 6 sawyers in my area that would buy the kit tomorrow.  The CBN wheel has great advantages over a standard wheels.
Custom sawing full-time since 2000.
WM LT70D62 Remote with Accuset
Sawing since 1995
Dan_Shade
I've heard that WM would rather you use resharp, and they sell them in canada due to no resharp in canada.
Does any other manufacturer offer a CBN sharpener here in the US?
lots of dull bands and chains
Faron
Yeah, but I don't want to be shipping blades back and forth all the time.  Grumble, grumble, gripe.  ::)  I would really consider a kit if one could be had.
WH_Conley
Yeah. What Faron said. I have a WM sharpener sitting in the basement. I am not going to be shipping blades, if I was I would not have bought the thing to start with. I would consider the upgrade though.
Bill
It's not that hard to get something from Canada if you are willing to pay for it!  ;) :)
WH_Conley
Yeah, bee thinking about that too.
Bill
