favorite blade
Started by steve phillips, January 19, 2012, 09:47:18 PM
steve phillips
helloooooo
whats everone favorite blade . brands ,tooth ect . if i figure right i can cut a log 30in dia with a 144 inch blade , that sound right ?
if its not broke dont fix it !!!!
paul case
The ez boardwalk 40 has an 14'6'' blade and max cut width is 36''. The LT40 I just never have measured width of cut on.
I have always used 1 ¼x.042x7/8 and I get along best with simonds red streak. Your results may vary ::) PC
pc
bandmiller2
Steve, all the name brand bands are good its just some mills prefer one over the outher.I'am trying out Cooks bands now they look promising,Mizers are reliable,I also like timberwolf.You will just have to try them on your mill.My bands are 167" and I consider 30" log to be max.If you want to diddle around you can take shallow slab cuts on a huge log, if you have the hight capacity,turn it a little and take anouther cut its called gun barreling, tough on a manual mill. Frank C.
FeltzE
Lennox woodmaster C 3/4 pitch 1 1/2" wide, verying kerf based on what we are sawing.
Chuck White
The blades for the Wood-Mizer LT40 are 158" or 13'2".
I have always used the Wood-Mizer Double Hard .045 x 1¼ x 158; 10°
They last for quite a few sharpenings, I average 6 - 8 sharpenings.
I can usually resharpen after striking a nail, to be good as new.
Kansas
My favorite blade is the one that we haven't found yet. The one that will cut just a little faster. Whatever you do, try different ones. Different species, different styles of cutting, frozen wood, etc., the mills themselves seems to yield different results with different blades. Most manufacturers will send a sample blade. Try some of different pitch, hook angle, and set. We run Woodmizers on several machines, including resaw. We run Kasko mostly on the big mill that uses two inch wide blades, cuts as good or better than Woodmizer in most applications. But we can't make a Kasco cut straight on the Woodmizer. Someone else's results will be different.
What I use is what was recommended by WM when I ordered my first/only batch of 60 blades.  I have always used the Wood-Mizer Double Hard .045 x 1¼ x 158; 10°.   They work well since a great majority of my sawing is SYP and other soft woods.
I use WM Resharp service and their blade replacement program, so my blade inventory now remains constant.
5quarter
MM...Are you saying that you have been sawing for 10+ years on 60 blades? :o either I'm misunderstanding or you truly are a sawing God!  ;)
Blue Harbor Refinishing
Buck
resharp replaces blades when they are worn out
Respect is earned. Honesty is appreciated. Trust is gained. Loyalty is returned.
Live....like someone left the gate open
FeltzE
WM has a autoreplacement program with their resharp program. So any reject blades are automaticly replaced and billed to your account.
Cost(s) resharp service $7 - $7.50 each. shipping $12 each way on a box of ten so $2.40/blade .... Total $9-$10 per blade to resharpen. Great if you don't want to do it yourself.
IF you want to do it yourself...
Sharpen 4-6 blades per hour  kinda like paying yourself $40-60 per hour for in-house maintenance and less overhead on blades, more on the sharpener. Ad $2k for your sharpener divde by 10 ... 200blades sharpened pays for the sharpener, everything after that is gross profit or savings depending on your viewpoint, unless of course you don't want to do it yourself.
eric
steve phillips
howdy all
thanks for all the input , i know so well some blade cut better than others on different machines. i used to build banjos and had a big old old delta bandsaw i bought for resawing , well my little 14 in bandsaw with a wolf blade cut faster and cleaner than the 20in would .
i still got a lot to learn and you guys rock with info
resharping service is the way to go for me unless i make a sharpener lol .
  ps just to let you know i keep notes on companys , info ect i hear from you guys , hope you dont mind but a man can only hold so much info lol   thanks
buildthisfixthat
my favorite blade lenox   Xstream prouduction thanks for asking
shop built bandsaw mill
5quarter
Ok MM...now that makes sense...rotating inventory of blades. Still think you're a sawing God... ;)
