dead rollers
Started by 4x4American, October 15, 2015, 12:37:31 PM
4x4American
Where can I get dead rollers to make a roller table with?
Boy, back in my day..
drobertson
sawmill exchange, salvage scrap yards, mills that have shut down,
fishfighter
Maybe find a store that is closing down. They use them to unload trucks. I been looking around myself. ;D
4x4American
All the ones I've found so far are rusted so bad they aint worth the powder to blow em to hell
sealark37
If you have access to a metal lathe, you can buy pipe or tubing along with shafting from the recycling yard.  Go on ebay and find the size bearing you need, and make rollers that will fill your need 100%.  If you cannot go that route, keep searching on CL and the scrap yards.   Regards, Clark
MP_Wall
The pallet racking resellers often have them listed in their stock but not on their craigslist ads. MPW
North River Energy
What kind of dimensions are you looking for?
Brian_Rhoad
Industrial auctions.  I've bought maybe 20.  Going price is usually $60 - $100 for a 3' X 10' table.  Either skate or straight rollers.  I kept the best plus a couple more incase I bend a roller, which has happened.  Resell the others on craigslist for a couple hundred, sometimes more.
Tree Dan
Wood Mizer LT40HD, Kubota KX71, New Holland LS150, Case TR270
6400 John Deere/with loader,General 20" planer, Stihl 880, Stihl 361, Dolmar 460, Husqvarna 50  and a few shovels,
60" and 30" Log Rite cant hooks, 2 home built Tree Spades, Homemade log splitter
4x4American
Quote from: North River Energy on October 15, 2015, 02:13:41 PM
I'd get whatever I can get my hands on, I'd like a table that is fairly wide.
Here's what I wanna do, since I'm on the mend, I can't pull boards like I did when I was about 2 months younger.  I want to be able to saw, drag the board back onto some sort of a table, and let it roll and then fall onto a pallet and sort of stack itself and then I can pick up the pallet and move it close to where I'm stickering or onto a trailer to be hauled off.  For the slabs I will push them off the roller table into a slab rack that I can keep clean with a machine.  Not only will it be easier, but it will be more efficient, especially once I'm back to 100%.
Kbeitz
Sounds like you need a pickaroon....
Love machine shop work
and Wood work shop work
And now a saw mill work
Get two or three roller tables and just put them down.  It won't be long until you change the layout, than change it again.
This is what works ok for me, a hobby sawyer.  I changed things around maybe four times before I was happy.
Sometimes I add an additional two tables so I can flip a cant off the mill backwards.
4x4American
Quote from: Kbeitz on October 15, 2015, 07:12:04 PM
I have two.   ;D
Thanks for the picture Larry!
Brucer
I made a heavy duty off-loading table for timbers, using the same rollers that WM uses on their twin blade edger. I just bought them as spare parts. They were expensive but they stand up to just about anything you can throw at them, and are weatherproof (unlike the inexpensive ones I bought earlier).
A little tip if you are building your own roller table. A lot of rollers have hex shafts and I see people drilling undersized holes, then filing them out to a hex shape. The holes don't have to be hex shaped. Just drill round holes big enough for the hex shaft to slip into. The edges of the shaft will provide enough friction to keep the shaft from turning.
Bruce    LT40HDG28 bandsaw
4x4American
Thanks, Brucer.  If anything I would cut a hole big enough for the hex to go through then weld a strip on the top and bottom to brace two sides before I got into filing out an undersized hole!!! Boy that must've taken half a year by the time you file out all the holes for a table!
Dave Shepard
If it was actually necessary to have a her home, I would have made a broach. I bought a could of 2'x10' tables at a scrapyard. They had four galvanized ones, but they had been crunched into pretzels by the time I got there. I drag back onto one of them and push slabs over the side onto blocking. Boards go off the end to a stack and flitches go through the edger and then onto the same stack.
4x4American
Would love to see a picture of that Dave!
Dave Shepard
I'll try to get one when I've got everything back together. Mill is moved to pour concrete.
4x4American
5quarter
Ever since my hex hole drill bit broke, I do what Brucer does... ;)
Blue Harbor Refinishing
Brucer
Quote from: 4x4American on October 16, 2015, 11:16:12 PM
... Boy that must've taken half a year by the time you file out all the holes for a table!
There's only 3 rollers on my outfeed table. They're spaced 42" apart because there's no danger of a timber sagging between them  :D. It was a pain filing the hex holes, but they were actually part of the structure of the table. If I were doing it again I'd change the design and go with the round holes.
4x4American
Quote from: 5quarter on October 17, 2015, 11:42:37 PM
lol lol  maybe u cud use a chisel?..heat up past cherry red, but not quite sheet white, and chisel it out! might go quicker!  But I'd try it on a scrap piece of similar material first.
Brucer I can't knock ya! Your setup and operation is what I'm gonna be modeling mine after once I can find somewhere to set it up. Do whatever ya gotta do, don't pay no mind to me!
Dave Shepard
If you had the right size hex on a punch, you could heat the rail and use the handle end of the punch as a drift.
4x4American
yea well now that u mention it i have hex's on 3/8" sockets, could just put a 6" extension on it and bam theres your drift.  Heat up the rail nice and lukewarm then bang bang tap tap on to the next one
