I recently acquired a B7100d Kubota and I would like to get a loader for it. They are very tough to find ao im curious if it would be worth it to build one. Has anyone ever made a homemade loader? Im guessing i would need to power it off the rear PTO? It does not have power steeribg but i am not looking to move anything real heavy, mainly off cuts and slabs.
This guy did one.
https://forestryforum.com/board/index.php/topic,96485.0.html
I think it starts on page 2 or 3. It's titled backhoe,but the loader is in there too.
Looks like a lot of work and with equipment I have,I could not do it.
I started reading that post earlier but jumped right to the last page. Holy crap that guy is an awesome fabricator, i dunno if im capable of building one but i sure can make an effort. Thanks for the reply!
I made one for a Power-King tractor...
(https://forestryforum.com/gallery/albums/userpics/39553/Fel_frame.JPG?easyrotate_cache=1504482979)
(https://forestryforum.com/gallery/albums/userpics/39553/Picture_number_3.JPG?easyrotate_cache=1504483038)
(https://forestryforum.com/gallery/albums/userpics/39553/It_works.JPG?easyrotate_cache=1504483092)
That powerking looks great! I have a case 222 that is hydraulic drive. Does that powerkings motor go right to a hydraulic pump like my case? How did you hook into the hydraulic system for the loader?
Power King tractors have there pump mounted above the flywheel with a
belt that runs down around the output shaft. It's a real pain to change the
belt when needed. All five of my Power Kings are stick shift not hydraulic
drive. Two of my tractors have double tyranny's. One I put a fork-lift on it.
(https://forestryforum.com/gallery/albums/userpics/39553/Going_up~0.jpg?easyrotate_cache=1504496386)
Since you say it's a 7100d and not dt, that means it's 2x4 not 4x4, right? With 2 wheel drive and no power steering, I think you will be happier with a boom lift on the back and weights on the front. It will handle better and be cheaper and easier to build in addition to actually keeping traction power on the ground.
I had a 2850 2x4 with no powersteering and loader work was a workout and needed an implement on the back to keep the rear end on the ground. I eventually sold the loader off of it for a kings ransom and both parties were tickled pink. ;)
It has 4 wheel drive but no power steering. I was told it was a 7100d but it could be a 7100dt i dont know. Doesnt have any D or DT on the logo just "7100 4 wheel drive" but it is gear shift.
We have a BX2670 with a loader, the machine is too light and under powered (26hp) to make full use of it. Without 4wd it would be useless even with the weight box. You sound a little unsure of your skills, a lot of engineering goes into figuring out stresses and leverages. Designing the hydraulics would also be a challenge. You might be better to look for a 35+hp farm tractor equipped with one. Just my opinion.
A front end loader is the handiest thing on my tractor. My tractor is rated 28 Hp at the PTO, has power steering and is 2 wheel drive.
Adding ballast to the 3 pt hitch improves handing and capacity of the loader. It's a see-saw, so multiply the load times the distance from the fulcrum to get an idea of how much ballast to use at the hitch.
You might find this interesting:
Power Steering for B7100-7200 (http://www.tractorbynet.com/forums/kubota-owning-operating/104139-p-s-b7100-7200-a.html)
If you decide to build your loader, I suggest you first look at Kubota's and aftermarket supplier's designs. Heavier structure means less payload. Lighter structure means easier to overload and break. Kbeitz's Power King photos above show all the elements necessary.
Quote from: TKehl on September 04, 2017, 10:10:58 AM
Tractordata.com has the b7100E listed as 2wd and the b7100d as 4wd
Quote from: sawguy21 on September 04, 2017, 12:51:29 PM
I would love to buy a tractor that large but i do not need one. I have access too a ls180 new holland skidsteer when i need to do heavy work. My tractor is 4wd i just need something for doing light work around my property and moving small loads. I definitely am unsure of my abilities but i feel i am capable of building a loader for it. In the meantime i will keep an eye on craigslist for used loaders for it.
Quote from: grouch on September 04, 2017, 01:18:30 PM
Thanks for the link!
I will definitely look at some loaders and get an idea of how heavy to make the frame. The part im going to struggle with the most will be fabricating the bucket. Ill be following your backhoe post and attepmting something similar to what you built for your ford.
I made a power steering setup for my b 8200. Works very well
http://www.orangetractortalks.com/forums/attachment.php?attachmentid=897&d=1261497261 (http://www.orangetractortalks.com/forums/attachment.php?attachmentid=897&d=1261497261)
This might give you ideas for the frame. (google search images)
There should be a way to tap into the tractors hydraulics to run the loader.
I have a loader on my 35 hp tractor and it is handier than a pocket on a shirt however making a frame for forks and a bucket for the rear would be a lot easier and carry more weight, with a trip release and/or hyd remotes and a hyd top link you can add a tilt function.
If I was you I would scour craigslist in your area for a used loader that is roughly the correct size for your tractor, then all you need to do is fabricate mounts and plumb the hydraulics. I often see loaders of various sizes without the tractor mounts or a bucket for dirt cheap, way cheaper than I could design and build one for (even using scrap steel, welding rod, hydraulic cylinders/hoses, pins, greasable bushings, etc all adds up really fast).
My little Kubota sometimes thinks it's to big....
(https://forestryforum.com/gallery/albums/userpics/39553/Heavy_load~1.jpg?easyrotate_cache=1504572717)
Quote from: Kbeitz on September 04, 2017, 08:52:12 PM
smiley_clapping smiley_clapping smiley_clapping smiley_clapping
I haven't done that.....yet ;D
KB how come every time I see pics of your kubota it never has 4 tires on the ground?
Now what fun would that be ???
(https://forestryforum.com/gallery/albums/userpics/39553/Friday-20135B15D~0.jpg?easyrotate_cache=1504629850)
I have done that with my jeep and very close with the tractor. but not yet.
Ok, left side test of the flop bar is successful. Now, how about the right side?
Quote from: grouch on September 05, 2017, 01:23:50 PM
Haven't done the right side yet... All that roll over did to my tractor was
lightened the color of one fender when the acid came out of the battery.
It almost darkened my underwear.
:D I came too close to doing that moving snow last winter. It definitely had my full attention.
I'm not too impressed with the brand right now myself. We have a back hoe for our tractor that has no more than 100 hrs of use. We have not been able to get it fixed going on 2 months now. It has been hauled back and forth to the dealer shop twice and not fixed. It is beyond the warranty, but was told no cost to us. I mean why should it, dead in 100 hrs? What a joke. I ain't impressed is a mild statement. :-X :-X
The kubota L2250 I used to have had a woods loader on it. It worked great but you could balance the tractor on the front axle with 1100 lbs in the bucket. It would but the JD that I have now to shame it would also skid logs well beyond its means. It had a 8 forward and 7 reverse gears, the transmission was also synchronized so you could shift from 1-4 or 5-8 kinda miss the old girl.
