Felling Rookie Help
Started by Mikeisme09, May 20, 2019, 10:41:16 PM
Mikeisme09
I'm a rookie and new to the site as well. I have enough saw, tractor, rope, snatch blocks, come-alongs and ambition... just not enough experience with these sorts of rotted or or beat up trees. Can one of you give me some advice as to how to attack this tree? I'm worried that it's gonna do whatever it wants to. I took a lot of trees down but these types intimidate me. The rest of the tree is in good shape. Thanks
Make The Woods Great Again.
BargeMonkey
Unless your trying to keep it off the house or something valuable trying to rig something like that with blocks / line ? could be really dangerous, the tops probably dead ? Something like that you can wedge a little, I would cut and drop it the way it naturally wants to go, everyone has an opinion on cutting methods, I would make a shallow face on the other side which is still probably good wood, bore cut thru till it's got 3-4" of tab on both sides in the back where its beaten, maybe insert a wedge ? cut 1 tab and then the other. You can do alot with a small wedge and knowing when to LEAVE wood attached, if that makes any sense.
Skeans1
Where is the weight of this tree? Is the lean opposite of the weight? Can you go 90 degrees of the cat face? My first instinct would be to go 45 or 90 of the rot(cat face) and chasing the back cut from the rot side to the good.
Southside
Like Barge said - let it go the way it wants to go.  The problem is you won't know what you have for holding wood until it's too late.  If you try to change the lean and your hinge wood is no good then it's going to go where ever it Dang well pleases.  That photo says to me hinge wood will be very, very, delicate.  Have two very good escape paths and proceed with caution.
White Oak Meadows
BargeMonkey
 Just have a clear exit and cut it at a comfortable height, alot of times with beaten stuff like that you dont have much good wood left and she will go before your ready, I've crushed a few saws before and learned all this the hard way.
BAN
If possible high stump just below the ribbon. Looks like you will have better holding wood above the rott.
Old Greenhorn
What Barge said, but take the time first to make sure your exit path is well cleared, get the heck out quick and keeping going. Keep looking up too. These trees can be tricky for a person who has not seen what they might do and can't predict what will happen well.
 A class with good hands on instruction will do you some wonders with this stuff. Tell us where you are and that will help the folks here help you. Filling out the profile info will save you answering that question repeatedly. Also, doing a search on this site will get you a ton of stuff and photos on problem trees.
 Welcome to the forum, pull up a stump.
Mikeisme09
Thanks much. Updated profile... Eastern UP is where my forest and camp resides. Will be working it this weekend and follow up with results.
Mikeisme09
Quote from: BAN on May 20, 2019, 11:33:22 PM
Got the tree down, followed Ban's advice and used better wood above rot. Down and split.
BAN
Quote from: Mikeisme09 on June 03, 2019, 11:25:46 AM
Nice work. I'm glad I still have a couple years of my high school boys splitting firewood.
Blackcanyon
Good job! Rotten /dead trees are a bit dangerous. The best way is to cut the tree and direct it towards its natural lean. I do not like to or advise wedging unless your quick like a cat. Often while pounding the wedge dead wood will come out of the crown. For future reference I would recommend a shallow front wedge cut and using a sharp saw start the back cut and stay with it looking up often. Being rotten they sometimes let go quick so be ready. If I sound cautious it's because I am. Use your head, develop a plan and proceed with confidence.
Blackcanyon
I will also add you are right to come on here looking for advise. For the most part I would say forum members know how to chop timber. How do I know that? If they didn't they wouldn't be around anymore to comment.
