who this man with the big chopper upperer
Started by iain, May 26, 2005, 02:07:34 AM
iain
Just got a new (to me) book anyone know who it is?
Dan_Shade
will malloof, that book has a lot of good info in it.
lots of dull bands and chains
iain
Its stuffed with good info
along with a good mind set
and advertising pipe smoking
iain
Dan_Shade
the pipe smoking while running a chainsaw mill is a bit amusing.
OneWithWood
Did Will Malloof play John Steed in the TV series the Avengers?
One With Wood
mike_van
Pattrick McNee played John Steed, Dianna Rigg was Emma Peel.  [my favorite]
johncinquo
So what did you pay for the book out of curiosity?  I have been told it is over $125 now.
I have 2!  And another called Barnacle Parps chainsaws and sawing.  Both are out of print in a big way.
To be one, Ask one
Masons and Shriners
Weekend_Sawyer
Is that book "Chainsaw Lumbermaking"? or did he write another.
I too have a copy, I made about 100bf and went out and bought a bandsaw mill! ;D
I beleive that's a Stihl 90 he's running.
Jon
Imagine, Me a Tree Farmer.
sawguy21
Stan
Yep, old Will was on tough fellar.  ::) I payed just under $100 for a copy of that book just over a year ago.  8)
I may have been born on a turnip truck, but I didn't just fall off.
iain
Not paid anything for it, its on loan from a friend,
good reading
  iain
Gilman
Notice he doesn't have the sprocket cover on that saw?
WM LT70, WM 40 Super, WM  '89 40HD
Cat throwing champion 1996, 1997, 1999. (retired)
iain
Nope, he says that when the saw is on its side, and up to the log it dont clear dust and chips very well, and the extra heat build up leads to extra clutch failure,
this is true, but i've not run mine with a cut down cover, dont think i will
        iain
Brucer
I bought Will's book when it was first published -- that's what got me into chainsaw lumbermaking. It took me a few thousand BF (and 20 years) to finally get a bandmill (slow learner,  eh?). I followed most of Will's suggestions but I really didn't want to go hacking up the sprocket cover. So I drilled a couple of holes in a piece of 1/2" x 3/4" steel and made a clamp to hold the bar on without using the cover. That worked great for sawmilling, and left me with a safe cover for regular sawing.
Got Barnacle Parp's Chainsaw Guide as well. Scared the heck out of me. I discovered I'd been cutting down trees for three years without having a clue how to do it properly. I'm still amazed I didn't drop a tree on me (did manage to drop one on the saw, however :()
Bruce    LT40HDG28 bandsaw
rbarshaw
And here from the post tytle I thought I would be seeing Paul Bunyon. :D
Been doing so much with so little for so long I can now do anything with nothing, except help from y'all!
By the way rbarshaw is short for Robert Barshaw.
My Second Mill Is Shopbuilt 64HP,37" wheels, still a work in progress.
Stan
Quote from: Brucer on May 31, 2005, 01:40:05 AM
IGot Barnacle Parp's Chainsaw Guide as well. Scared the heck out of me. I discovered I'd been cutting down trees for three years without having a clue how to do it properly. I'm still amazed I didn't drop a tree on me (did manage to drop one on the saw, however :()
I dropped one on my log splitter which I thought was 180 degrees from the place the danged tree'd fall.  smiley_swinging_board
rbarshaw
I dropped one on my tractor once. I was cutting on the tree and realized the tractor was inline with the intended fall, so I moved it to a different spot and out of range of the tree. Well that tree grew 30' while it was falling right at the tractor, just did a little cosmetic damage, but I learned to never trust a tree again!
sawguy21
Feller I worked with dropped one across a Jet Ranger tailboom. He forgot about the onshore wind. They were working on the Ungava peninsula in northern Quebec and it was almost two weeks before they  got the word out to order a replacement.
