Broke a blade today with most unusual results.....
Started by Percy, December 05, 2016, 11:07:38 PM
Percy
Quote from: Brucer on December 07, 2016, 01:27:25 AM
About half of mine come out without any hassles. The other half are a total pain. If the blade isn't broken but is badly kinked (a write-off in other words), it's easy to break with a claw hammer.
My friend Bob coils his blades by stepping on them (as shown in post #10). He uncoils them by tossing the onto a pile of sawdust. Mind you, he's only got one arm so he doesn't have too many other options.
Im going to hell for this but I shot coffee outta my nose when I read about "Bob, the one armed sawyer"...  :D :D :D :D :D :D :D :D
Sandtown Sawmil
What are some of the choices on broken blades?
Buy a new blade or try and fix the broken blade?
When a blade finally breaks metal fatigue has compromised the entire blade.  Fix it in one spot and it will soon break in another.  A hobby guy might try to squeeze some more life out of it, but if you are making any kind of production whatsoever, that blade has given you it's life.  Let it die.
Sandtown Sawmil
Brucer
Bob's arm was taken off at the shoulder several decades ago -- apparently in a sawmill accident. It hasn't limited him in any way.
First time I saw him, I watched him (along with his father and his uncle) win the first-ever wood-splitting contest in our local fall fair. The were competing against 9 other teams and left them in the dust. He runs a chainsaw (with a prosthesis), swings a splitting mall one-handed, and picks up split wood with a pickaroon.
He used to run a Logosol chainsaw mill to cut timbers for his own use. Logs his own property. Cuts, splits, and delivers firewood. And last year he bought a Woodland Mills HM126 (and conned me into sharpening his blades for him)  :D.
For several years he worked for the City works department as an equipment operator.
Bottom line -- there isn't anything that he can't figure out how to do, one way or the other.
Bruce    LT40HDG28 bandsaw
Delawhere Jack
On my 1995 LT40, I just LOVE IT when a broken or just knocked off the wheels band gets stuck behind the drive side wheel. There's a hex bolt head in the back side of the cover at about 1 o'clock that makes it OH SO MUCH FUN when the band gets caught behind it!  >:(
It's on my to-do list to replace it with a carriage bolt or something, but my to-do list just keeps getting longer, and it keeps falling to the bottom of the list. ::)
redprospector
Quote from: Brucer on December 07, 2016, 10:47:49 PM
My Dad lost his right arm in 1935, he was 8 years old. He would not be out worked. I never saw anything he couldn't do. His left arm was the size of my thigh. He even rolled his own cigarettes. :D
The worst thing you can do is sell a one armed man short.
LeeB
I hadn't even considered a prosthesis. I worked with a welder several years ago the had a missing arm. He made a lot of different attachments for his prosthesis to use in his daily work and others for off work. I always got a kick out of seeing him sharpen one with the grinder or weld a part to it for better control.
Knew a superintendent for a drilling company back in the late 70's that had lost both arms on the rig. Didn't slow him down any. He could run a rig better than any of the drillers with both arms.
paul case
Quote from: Delawhere Jack on December 07, 2016, 11:06:47 PM
When my oldest son first started sawing with my old LT40, He knocked the blade off several times. He thought it worked good to use a crow bar/shop hammer tool we call the slammer to drive the band down from behind the drive wheel. It did except he missed once and broke the wheel between 2 spokes. His miss made a $250 repair necessary.
I wasnt too happy. He quickly figured out how not to knock the band off the wheels.
PC
pc
mrtwister
Played in a band with a one-armed drummer....name was Rick....born with his left arm cut-off below the elbow....in his case that was his "snare-drum" arm.....he cobbled-up some kind of tube/prosthesis that he slipped onto the "stump" of his arm...then would slide the drumstick inside the business-end of the tube...not sure how it was held in there but it never came out....he was one of the better drummers I'd ever played with.....didn't let the disability stand in the way of what he wanted to do...pretty inspiring.
Norwood ML 26 Mill, Log Arch, Kioti DS4510HS Tractor with Grapple, Chainsaws: Dolmar 510, Husqvarna t435 arborist chainsaw, T-Rex walking beam trailer, CF Moto U-Force 500 UTV.
tnaz
Quote from: mrtwister on December 08, 2016, 08:36:30 AM
Thanks for sharing that story, and welcome to the Forestry Forum.
Terry
Darrel
Worked in a furniture factory that had a resaw with a 2 1/2"  band. There was also an old sawdust pile out back. I'd just give the coiled up band a toss and let it land on the sawdust pile. There was a nice twanging sound and flying sawdust and the best part was no blood!
1992 LT40HD
I don't throw sharp bands to open them but a sharpening customer has long heavy bands and when they come to be sharpened I throw them on the lawn to save meat, my own. Frank C.
