Band saw wheel width.
Started by Grower, March 31, 2024, 10:45:35 PM
Grower
Hello, I am running 1 1/4" blades on 3/4" wide x 24" diameter bandsaw wheels, never had a problem. What am looking at doing is running 1 1/2" blades on the same wheels. Will they be wide enough?
Its better to have it and not need it than to need it and not have it.
Southside
Well I run 1 3/4" on my super 70 and the band only runs on top of the V belt, so from that perspective I don't see an issue.
White Oak Meadows
DanielW
I think you'll be fine with wheel width. A few other aspects that might be concerning are:
a) Blade Guide: Often needs to be changed out (or modified) for 1 1/2" bands.
b) HP: You don't see much advantage to 1-1/2" unless you have the HP to pull it - assuming you're using the more common 1-1/2"s which are a little thicker. I'd say you really need at least 20 HP (preferable at least 25) to be able to pull them and see any significant advantage.
c) Mill Build: Wider blades generally run a little truer with less wave, but you need to be able to put a little more strain/tension on them to see this. A lot of the smaller/lighter mills these days can't handle much extra strain/'tension being put on them without the wheel/bearing mounts flexing and causing tracking problems. Not a concern if it's a heavier/well-built powerhead.
Grower
Good advice! It has a Mitsubishi K3H diesel fitted, turned out to be a great wee motor, depending which specs you read its either 24 or 27hp I will stay with the 24hp as when it was sold to me, unsure of what it came out of though, I was told possibly an air conditioning unit from a bus but they are also used in Mitsi MT250 tractors, it runs on the sniff of an oily rag and great lugging ability especially when we were cutting 140 year old macrocarpa that was 3 feet through. The mill pulleys are fitted with 1 1/2" shafts at each end as a footnote. I will stick with the 1 1/4" blades after reading this. Thanks chief!
DanielW
It sounds like you have enough power (your 25 HP diesel will probably pull better than a 30 HP gas) and it sounds like a sturdy, well-built mill with decent wheel diameters. I'd think you could pull of 1 1/2"s just fine and see a reasonable gain in stability/wander. You might still have to modify your blade guides, but not a big deal. I'd be curious to see some pics of that mill.
esteadle
