Stickers out of pallet boards
Started by clintnelms, July 10, 2016, 02:26:49 PM
clintnelms
Anyone ever used boards from pallets and made stickers out of them? I know they're not typically 1 inch thick, but I can get virtually an unlimited supply. I was thinking I could rip 1 inch strips off of them and use them. I think the boards on my pallets are about 3/4 inch thick. Just wanted to hear others thoughts on it.
DDW_OR
I cut my own from the scrap from the logs i cut.
I have never used Pallet wood, but it may stain the lumber.
WV Sawmiller
   All my stickers come from my edgings or from scrap logs. I'll take a 3-4 foot top and rip into stickers. Actually, I use almost exclusively 3' long stickers to match my pallets. I cut up a bunch of odd 1' and 2' stickers out of broken ones and such for those oddball small stacks of lumber of slabs I generate along the way.
   I'd think I could cut scrap and edgings faster and easier than cutting up old pallets and not have to worry about hitting nails and such and disposing of the other pallet remnants.
Air flow is the key to drying.  Much less than an inch would be sorta restrictive.
Kbeitz
I think after you try pulling a few boards off pallets that you will change your mind.
They put them on to stay...
Love machine shop work
and Wood work shop work
And now a saw mill work
clintnelms
Quote from: Kbeitz on July 10, 2016, 07:17:59 PM
I wouldn't be pulling them. I've got a buddy that sells pallets and he pulls the good boards from the bad pallets and has tons of boards already pulled. I just seem to always have to cut more stickers everytime and not have any that are already dry. So had just thought of the pallets one day and was wondering.
paul case
Wet boards and stickers that have metal fragments in them may cause blueing on your lumber.
I don't sticker that much lumber but I have always had enough from edging  to make what I need. I  would give you a log er 2 if you want to come get them to make stickers out of.
PC
pc
Czech_Made
Go for it if it's worth your time, but I am afraid there will be too many nails left and from what I have seen, the pallet  boards are far from uniform.
alanh
I was cutting them from scrap and flitches but patience isnt one of my strong points so one day I "sacrificed" a nice ash log and made a kijillion of them and put them on a pallet up on a rack, I`ll have enough for a while
clintnelms
Quote from: paul case on July 11, 2016, 09:34:39 PM
PC
Thanks Paul. I appreciate the offer. I'm in Southwest Georgia so I think I'm a bit far from ya. I'm down for a while because I just had carpal tunnel surgery a few weeks ago. Hopefully in a month or so I can get back to sawing. It's driving me nuts seeing my saw sitting there and can't use it. No one to help so I'll have to wait.
It's too DanG hot to saw anyway.   smiley_sweat_drop
POSTON WIDEHEAD
red
Says the goat who has it made in the Shade
Carson-saws
Stickers are tricky.  I have been told by buys not to sticker "their wood" at all.  Seems many times no matter what you may use,, be it dried stock or cut from stock the staining occurs.
Let the Forest be salvation long before it needs to be
steamsawyer
I'd like to have the pallet wood to fire my boiler, sometimes I run short of slabs. I used  to almost exclusively burn pallet wood in my steamboat. Hot, clean, and not too much ash.
J. A. Vance circular sawmill, 52" blade, powered by a 70 HP 9 1/2 x 10 James Leffel portable steam engine.
Inside this tired old mans body is just a little boy that wants to go out and play.
Great minds think alike.....  Does your butt itch too?
Alan Rudd
Steam Punk Extraordinaire.
clintnelms
Quote from: Carson-saws on July 17, 2016, 11:10:24 PM
A little confused on what you mean. Are you saying that some guys say not to sticker wood at all? To just stack it with no stickers? I don't really care about staining at this stage right now. Most lumber I'm making is for use on the farm for outdoor shelters and stuff. I'm too new at milling to be worried about stained lumber. I'm a ways from making lumber for furniture or anything.
clintnelms
Quote from: Magicman on July 17, 2016, 08:01:00 AM
You are right about that! I don't even want to go out the house right now.
Carson-saws
clintnelms...yes...the buyers I have dealt with told me never to sticker "their" wood.  any other time the wood IS stickered.  Personally,  depending on species, grade, length and application, I will not always stick to "protocol" or "sticker standards"
  For what you are cutting for, like you said, your goals are to: learn more...what works for you...applications and I can say with confidence that pretty much everyone on this forum had to start somewhere.  So with your intentions and use in mind, in my opinion,  if you are building off the mill than no worries.  If you have the intention of "somewhat" drying the wood for your use than sway a bit from "sticker standards".  Again, as you gain your experience and find YOUR comfort zone build you knowledge you will enjoy you mill even more.
YellowHammer
Some buyers and sellers won't sticker wood, as improper sticking will begin to leave zebra stain that is hard to clear.  It's much easier to coordinate the sawing time, dead stack, and then sticker properly when the packs get to the destination, where the dryer properly stickers them. I personally have bought many units of green wood from other sawyers and I always tell them not to sticker it. I also will coordinate their sawing times so I can get the dead stacked wood within a certain time window.   Stickered wood is also difficult and dangerous to transport on a trailer.  Sawing and dead stacking greatly depends on season and species and around here, the hardwood mills have a definate seasonal sawing rhythm.  For example, very few mills locally (including me) will saw red maple or poplar in July and August, and much prefer the dead of winter.  Oaks are summer sawing species, but do have a dead stack shelf life, while Walnut and cherry, which are extremely resistant to sticker stain, can be dead stacked for much longer before degrade begins.
If you are short on stickers, then it's time to chuck up a log or two and saw out a pallet full.  You can never have too many stickers.  I sticker 7 per row, 30 rows per pack, so 210 stickers per 840 Bdft pack.  I try to saw several packs a week after work, so even only 4 packs will take 840 stickers per week, and if air drying on a cycle time of 6 weeks, that comes to over 5,000 stickers in the rotation.  My point is that sawing stickers isn't fun, but it's part of the game.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
clintnelms
Thanks everyone for your comments and suggestions. Makes a lot of sense.
