Old 2 cycle oil
Started by chuckp, June 27, 2011, 06:03:06 PM
chuckp
I just got about 12 pints of old 2 cycle oil. The label says Granbers, Eutectic 2 cycle oil for chain saws. Mix 100:1 ratio.
Is this still usable, if so, how should I mix it for my Husky chainsaws?
I don't think oil really goes bad, as long as it's not contaminated with water or some sort of crud. Not like a fuel mix does anyway.
If it looks good I would use it, and just mix it to the normal 30 - 40 - 50:1 ratio that you use normally. The manufacturer reckons it will be ok at 100:1, but I'm not that optimistic. Mixing a better quality oil at the standard mix ratio wont do any harm.
tyb525
Mix it at whatever ratio you normally mix your oil and it should be ok.
NCFarmboy
Quote from: tyb525 on June 27, 2011, 10:29:15 PM
Like he said!
NC
Lots & Lots of Saws
clww
If it's still sealed up in a can or bottle unopened, I'd use it at 40:1 or 50:1. Whatever is recommended for your saw.
Many Stihl Saws-16"-60"
18-Wheeler Driver
