blade guide bearing&frozen sawdust
Started by 47sawdust, November 17, 2019, 06:56:51 PM
47sawdust
Sawing frozen pine and hemlock today and my adjustable blade guide bearing fills up w/frozen sawdust.The fixed side runs clean.Is there a solution or just one of the joys of winter sawing?
Thanks for your input.
Mick
Stephen1
Are you adjusted correctly? Are the blade guides rolling/spinning with the blade? With full tension on the blade see if you can spin the rollers by hand. If you can, you do not have enough down pressure on the rollers.
