glow plug indicator
Started by slider, January 18, 2012, 12:21:30 PM
slider
May be marty or sparks can answer this one.On my lt 70 remote ,sometimes ,not always the glow plug indicator light will stay on after the engine is running.Will this harm anything ? Relay sticking Amby.Is there a test i can perform to be sure that the glow plugs are not staying on after the engine is running ? thanks al
al glenn
jueston
how long does the light stay on? it seems to me if the glow plugs were staying on too long they would be burned out by now....
but i'm sure someone who knows more about the lt70 then me will be here soon with some specific knowledge...
slider
jueston it stays on until i switch the key off sometimes.I was thinking the same thing burned out glow plugs.I would think it would go out when the engine starts.Sometimes it goes out right away sometimes not.  thanks  al
al glenn
I figured that Marty would pick this up by now.  My suggestion is to call WM.
MartyParsons
Hello,
I am out standing in a field. At a show.
The relay is sticking. It will make the glow plugs stay on and shorten the life on them. Remove the glow plug relay and shake it. If it rattles the diode came loose. Could also be the connections at the relay loose. There is a timer on the relay it should only stay on for 45 sec. . The relay should turn off once it sees the starter engauge.
What revision is the 70?
Marty
terrifictimbersllc
The advice above plus check the voltage at your glow plug strip to see if it is on after the engine starts.  Wire going to strip across plug area, coming from relay.
