that seems to have magical properties.......
A year ago the tilt function on my A300 bobcat quit working. Called bobcat with fault code, defective tilt actuator. 1000.00 Canadian they said. I thought Id check all connections and hook up multimeter etc just incase it was a simple thing. Bad news. Everything was as it should be cept the thing was non functional. I grabbed the magic hammer and gave the actuator a whack. It started working. I was happy. About every 6 months, I gotta whack the actuator with the "special" hammer.
Today I had to rebuild/patch together my hydraulic pumps on the LT70. Im waiting for new units but need to cut so, the one still functional pump wasnt cutting it. Slower than a stoned sloth. :D The one that died a while back was not turning. I had already determined it was the hydraulic portion of the unit as the electrical part was fine. Just a seized up hydraulic pump. So, after my earlier successes with the magic hammer, I thought, what the heck. One manly smack to the hydraulic pump and the unit is working like new. Im thinkin of renting this hammer out
Your not the only one to have one... They started selling them on E-bay...
The call it the latex Hammer ... $33.00 and $2.95 shipping...
just be careful how hard you wack a DC motor.
used the hammer on the blade guide motor on the TK-2000. it worked
later did the wack when i was frustrated and shattered the magnets in the motor.
Quote from: Kbeitz on August 08, 2017, 01:03:31 AM
I dunno....I think mine is magic......Id want more than 33 bucks for it ;D
Quote from: DDW_OR on August 08, 2017, 01:08:26 AM
You have a magic hammer too!! Thats awesome. Sounds like it needs a little training(magnet thing) . ;D
Stoned sloth =wet week =forever,for some of us less patient types :D
Quote from: woodyone.john on August 08, 2017, 01:54:43 AM
That would be me too. Stoned sloth and forever, I understand. "Wet week" needs some explaining.... :o ;D
I coulduse a hammer like that cuz the one i have hates my left hand :D
Quote from: goose63 on August 08, 2017, 07:16:20 AM
Ya! :D :D Left handed ones are hard to find.
"If at first you dont succeed get a bigger hammer" as my dad would say.
Good old percussive maintenance - works every time except when it doesn't. ;D
Quote from: longtime lurker on August 08, 2017, 08:11:10 AM
LOL@percussive maintenance 😂😂
A hammer is always my primary tool. I reach for it first in most situations. Did i ever mention I USED to work on airplanes?
Never use force.... Just get a bigger hammer.
How much to rent your magic hammer? ... My tilt is not working on my MF... ??? :P
Quote from: campwags on August 08, 2017, 01:16:30 PM
well if you come and pick it up, it won't cost you anything. You could be here in....a week if you left now. 🤓
As I like to say, "If you've got a big enough hammer, you can fix darn near anything!" :D
A fellas bulldozer quit, he called the old mechanic. The mechanic wacked the final drive with a big hammer and handed the guy a bill for $300.00 The owner was incensed that much for one hammer blow. The mechanic itemized the bill $1.00 for hammer blow $299.00 for knowing where to strike it. Frank C.
A man is in court for murder and the judge says, "You are charged with beating your wife to death with a hammer."
A voice at the back of the court says, "You bastard."
The judge continues, "You are also charged with beating your daughter to death with a hammer."
Again the voice at the back of the court says, "You bastard."
The judge says, "We cannot have any more of these outbursts from you. What is the problem?"
The man at the back of the court says, "Fifteen years I lived next door to that bastard, and every time I asked to borrow a hammer, he said he didn't have one!"
In this neck of the woods, we call a hammer fixes things like that a "Persuader." 8) 8). All the best, Rob.
Good ole back and forth wrench saves the day
If it won't move hit it.
If it breaks, well it needed replacing anyway :D
Mankind's first tool. In skillful hands can work wonders, unskilled hands wreak destruction. Frank C.
Quote from: 4x4American on August 08, 2017, 10:41:21 PM
And when that doesn't work ... HEAT WRENCH!
(https://www.picclickimg.com/00/s/NjYwWDE2MDA=/z/pusAAOSw8w1X~o6J/$/Acetylene-Cutting-Welding-Torch-Tip-Fits-Harris-_1.jpg)
Why do we all say it this way? Because you actually need to go forth before you can come back. No? :D :D So then it becomes a forth and back wrench? ;D We play with that phrase here too and we get teased mercilessly when we use it. Oh well.
Nope, you (I) gotta go back to gain the momentum before I can swing forward. The "taking aim" doesn't count because you didn't hit anything yet. ;)
Now you went forth and I went back so the conversation is at least forth and back. Let the games begin. :D
Does this magic hammer work on co-workers?
QuoteDoes this magic hammer work on co-workers?
While i dont actually own the magic hammer... Im going to say it works wonders on co-workers. May take more than one whack but you'll get what you are looking for eventually.
Quote from: Bert on August 09, 2017, 04:15:09 PM
and a vacation to the slammer
Just make sure you get it calibrated at a reliable lab before you use it.
Gerald
one place where the magic hammer does NOT work is on permanent magnet motors. I changed out 2 feed motors recently (2 different mills) from some knucklehead banging on the motor to tighten the belt. Then magnets are very brittle.
Quote from: pineywoods on August 09, 2017, 08:35:17 PM
Sounds like you need some magic JB-weld.
Quote from: Grizzly on August 09, 2017, 12:30:37 PM
Ever listened to some lyrics in songs? They'll say something that rhymes or rolls off the tongue before they say something that makes sense...back and fourth...they cancel
each other out so it's really a wash anyways, who cares where you started...should I have said
other each? The people that tease you about such a mundane thing, follow them out into the parking lot and see if they have to back out of their spot before they go fourth with their motoring. ;D
All tools are hammers except chisels, those are screw drivers... :D
Quote from: tree-farmer on August 10, 2017, 04:49:43 AM
:D :D :D Reminds me of this song
https://www.youtube.com/watch?v=CwGrC0KicSo
Great song Percy! Thats my neighbor to a T
My pet peeve (one of many actually) is the phrase "Over and out". I guess it flows like Back and Forth does but in proper radio communication Over means you are finished talking and expecting a reply. Out means you are finished talking and shutting down the conversation. It is never both.
One fellow that I work with has a sign on his toolbox, " If I can't fix it with a hammer, you have an electrial problem. "
Yes, he works in equipment maintenance.
Lol
I have a full set of hammers . It's like a socket set only different . I have found that like sokets and screw drivers I can never find the size I'm looking for .
