Buying a trailer, need advice!
Started by PJinN.E.Texas, January 23, 2012, 06:14:53 PM
Qweaver
Remember the 26,000 limit to avoid the CDL rule.  With a ton truck you will be limited to a 14,000 gvw trailer.  I opted for a 3/4 ton just for this reason.  I have been stopped by the DOT 2 times in the last 2 years.  No tickets because I was legal.  A gooseneck 25' 14,000 lb trailer is bearly enough for my equipment.  5ea. 2000lb logs maxes me out.  I could have bought a 16,000 gvw trailer and still been legal but then I'd have 8 wheels and tires to keep up with rather that 4.
If you are a farmer you can get by with more gvw but not if you make long hauls.
Most tag-alongs will not be rated above 10,000 gvw and may be really hard to pull with those loads anyway.
Quinton
YellowHammer
I have a custom built 14,000 lb dump trailer with 20,000 lb rams and undercarriage.  I added a used service crane that I rebuilt over several months (I got the idea from Redbeard) and use it to cleanly and quickly hoist up free logs from neighborhood yards where they don't want their grass messed up.  I also get a lot of free logs from farmers who don't want to spend the time removing fallen trees from their field edges but also don't want to have to dodge them with their corn crops.  So they just want the trees to disappear, and I can stay on the field roads and use the crane to drag the trees to the trailer and load them without needing help from the farmer.
YellowHammer
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Ironwood
YellowHammer,
Nice rig. I call the ability to "reel" them in "fishing". This is something hard to do without a winch somewhere on your rig to at least put a pulley on the end of the boom to get ones farther away.
Ironwood
