Drum switch - no forward feed
Started by WV Sawmiller, April 13, 2016, 09:30:50 PM
trapper
fleet farm here in wi.  Try marine dealers also.
barbender
I've had to use the liquid electrical tape a couple of times when DanG mice got in my control panel and chewed insulation off of some wires. It goes on like thick paint, just keep layering it on until well coated.
WV Sawmiller
kbeitz & barbender,
   Thx for the info on the liquid electrical tape. I'll keep that in mind.
   So far no issues noted with mice but the scout wasps were out in large numbers yesterday scoping out my mill in detail for a housewarming party. I'll have to keep an eye out for them.
Kbeitz
Been getting mine at Home Depo and lowes. Any electrical supply store will have it.
Love machine shop work
and Wood work shop work
And now a saw mill work
slider
For those of you running a remote mill don't forget the connectors at the back of the remote station.That is where my problem was last time.
Also a weak brush spring can cause this.
al glenn
