Solar kiln floor insulation??? Edit… my solar kiln project
Started by Nebraska, May 23, 2024, 10:48:37 PM
Nebraska
Leaning towards 3/4 inch foil faced polyiso..  Just wondering what feelings were and others choices had been.  I could go 2 inch if need be.  Building on top of 5/4 recycled deck boards.
Southside
Isn't that the while open pore stuff?  I would be concerned with water getting into it.
Nebraska
Well I didn't think it was, I thought it kind of looked like spray foam between aluminum foil. My plan was to sandwich it under some plywood then maybe use a cheap waterproof closeout click vinyl for the floor if it will take the heat. Or maybe cheap ceramic tile on cement board. At the rate I am moving maybe it will be done by next year.  :wink_2:
blackhawk
I would go with the 2" thick foam.  That is what I used beneath the concrete for my DH kiln.
Lucas 7-23 with slabber. Nyle L53 kiln. Shopbot CNC 48x96
K-Guy
@Southside
@Nebraska
It is moisture resistant, so I would recommend a vapor barrier between it and the floor. Use 2" of the polyiso.
Nyle Service Dept.
- D. Adams
scsmith42
I used 6" of closed cell insulation in the floor, walls and doors of 3 of mine.  They get hotter in the summer than my 4th solar that has 4" poly-iso insulation.
Tom's 3638D Baker band mill
Nebraska
6 inches may (ok will)...require me to noodle on my design a bit more. I was thinking 3.5" in walls etc.
scsmith42
Re wall thickness, it depends upon how cold your climate it.  In my area I'll have solar kiln temps over 100 degrees in all but 2 months or so of the year (in my 3 kilns with the 6" insulation).  In the kiln with 3.5" insulation, it's more like 8 months of the year.
Do your thing @Nebraska.  as you get thicker there is less bang for the buck.  as Gene W told me, "It is only a solar kiln".  I think he knew I was making it too hard.  I have still not built my first trying to make it harder than it has to be.   ffcheesy
farmfromkansas
I used a welded pipe frame for a base, put some straps sticking up to bolt the floor to, then used 2x6 floor frame, turned it over and put plywood under the floor frame, turned it over and bolted the floor to the pipe frame, put 2 layers of r-11 insulation in the floor frame, put plastic down over the top, then layed t&g flooring.
Nebraska
Well my base is two REA poles squared up, with laminated 2x10 beams on 16" centers with a layer of recycled 5/4 deck board that were too good to haul to the land fill.  It's over kill, then insulation with some sort of plywood floor. Walls haven't been decided yet.
Nebraska
Nebraska
Well it was underlined in the preview.   :wacky:
Nebraska
Nebraska
Made some progress again on the kiln. Knee has started to feel like piddling around with it. Yes I'm using recycled pallets. They will get stainless steel fasteners added, soaked with solubor, and treated with some good permethrin I have on the shelf before I sheet and insulate it.
Wind chill is supposed to zero tomorrow morning so maybe not much progress on my day off.  ffsmiley
YellowHammer
Wow, that is some wide open spaces! Beautiful country, but cold looking.
Good progress.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Nebraska
Yeah it's 7 to the good side of zero right now. Lots more corn than trees.  ffsmiley
Just bugs in general, it will sit on a cement grain bin slab, on 6x6 creosote REA pole skid with a doubled up 2x 10 floor joists. There's lots easier wood for the termites to get. I don't want it totally packed full of Asian Beetles.
Thanks for the link beenthere, the product I keep at the office does have a subterranean termite label.
Nonetheless I elect to work indoors this morning.
Nebraska
https://forestryforum.com/gallery/displayimage.php?pid=356996][/url=https://forestryforum.com/gallery/displayimage.php?pid=356997][/url]
Seven degrees was too cold this morning but late afternoon wasn't too bad wind laid down and it was in the 20s so I worked a little more. God gave me a beautiful scene to finish it.
YellowHammer
The cool thing is as soon as you box it in and put the clear panels on, it starts to really warm up.  Like a sunroom and it will stay comfortably warm, well before it gets finishes.  With that view, I'd probably just put me a lawn chair in there, and enjoy the sunset.
YellowHammerisms:
shoulda made a round one the size of that pad that turns on a turret to follow that sun till sunset! ffwave ffcheesy ffsmiley
Nebraska
If I remember correctly it was a 20,000 bushel grain bin on that pad. It was sold off before we bought the place. At this point my staff is balking at the idea of loading a solar kiln with that much capacity. If it wasn't so far from the house think it would be a nice place for a hot tub cabana/ sunset deck and a little bar.   ffsmiley
Alas mostly it's scrap metal  storage, a level spot to air dry and a place to build small projects.
Nebraska
Not really picture worthy, it was a very nice day considering last week we had below zero's. I worked on the kiln, got the roof side rafters cut out of some cottonwood 2x that dried pretty straight. I had a 1/4 of a can of ready seal and coated them to waterproof them a little. They will likely get rained on before the kiln is dried in and I have too many memories of cottonwood fence boards becoming noodles in the weather from my childhood.
I also got the air compressor over there and put a stainless steel staple in each pallet board. That should keep it sturdy enough for a while.  I had dreams of sawing today but didn't get there.  As someone else says "tomorrow's another day".    ffsmiley
Nebraska
Short side rafters got on the night before last as it got dark. Ordered some small radiator fans to mount in a built up header at the end of the collector.  I found a couple of fairly inexpensive 12 volt solar panels to install....my question is, do I need to add a battery/ charge controller between the panels and the fans or can I just get by straight wiring them to the panels ???
I was going to add a cut off switch in to the circuit but that was it. Gets dark, fans quit running wood rests. Day light comes and we go again.  Do I need anything between??
I have one direct on a solar heater I made with boy scouts.  they were a set.  I have heard of folks using no battery.  I assume these are 12 volt fans?  If you use and inverter and 110v fans it might be better to get to a certain voltage before they kick in.  the panel and fan set together work well.  If you did a battery or two, then you could invert the voltage and maybe use a separate control for a definite on and off by voltage, time or daylight.  I worry about low voltage as the sun comes up on an ac motor.  I am not a solar power expert by all means.  batteries are a consumable, so the cost keeps going up as you increase complexity.
